what would be a good bookshelf to replace RTi100?
Dannieboiz
Dannieboiz Posts: 242
edited January 2005 in Speakers
I'm thinking about replacing my RTi100 with some bookshelf speakers so i can mount them. I moved my home theatre to a different room and the RTi100 doesn't look to good sitting on the floor. I just bought some CSi5. I love the way the Rti100 sound, want to get something smaller w/o sacrificing any sound that the RTi100 are putting out. I also use this sytem for my main music. here's what I have
Rti100
CSi5
FX500i
NHT Subone subs
HK AVR500
the room is about 15x15
Sammy UN55C6400
Onkyo TX-SR875
Def Tech: Mythos One, Three, Six
Velodyne DPS-12
MartinLogan Dynamo 10
Post edited by Dannieboiz on
    VR3 Posts: 29,395
    edited January 2005
    RTi6?
  • Dannieboiz
    edited January 2005
    that looks like it'll be my only option but Polk recommended only a CSi3 as center. Wouldn't that be a waste for the CSi5 matching them with the RTi6?
    Sammy UN55C6400
    Onkyo TX-SR875
    Velodyne DPS-12
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited January 2005
    The CSi5 will match up fine with the RTi6...
    VR3 Posts: 29,395
    edited January 2005
    Buy two pairs...stack em! ;)
  • Dannieboiz
    edited January 2005
    alrite off to the store to pick some up.
    Sammy UN55C6400
    Onkyo TX-SR875
    Velodyne DPS-12
  • Dannieboiz
    edited January 2005
    I would I hook 'em up? I doubt my HK can handle 4ohms load.
    Sammy UN55C6400
    Onkyo TX-SR875
    Velodyne DPS-12
  • AsSiMiLaTeD
    edited January 2005
    first, I'd think that HK can handle 4ohm loads.
    Second, I wouldn't suggest stacking them or whatever...
  • Dannieboiz
    edited January 2005
    Arghh you guys are killing me... to by or not to by... hmm LOLZ :D
    Sammy UN55C6400
    Onkyo TX-SR875
    Velodyne DPS-12
  • EricH
    EricH Posts: 140
    edited January 2005
    Buy one pair of RTi6's. They have the same tweeter and driver as your CSi5 so they're a perfect match. However, you will "sacrifice sound" as you say. A 15" bookshelf simply cannot duplicate the sound of a 44" tower with powered subs. However, there are some who may even say bookshelfs sound better, so you'll have to listen for yourself.
  • Dannieboiz
    edited January 2005
    Last year I tried a pair of LSi7 for my fronts but for some reason I hated it returned them the next day. But that was when I had no real center piece nor surrounds. Just some cheapy 8" subs to compromise. Lack of bass killed it for me, one thing I didn't do was to turn off the subs on the RTi100 the compare, that may have been different. That's the reason why I'm weary about theRTi6.
    Sammy UN55C6400
    Onkyo TX-SR875
    Velodyne DPS-12
  • AsSiMiLaTeD
    edited January 2005
    I'm of the school of thought that bookshelves do sound better, especially if you have a good sub to compliment them, which he does...
  • EricH
    EricH Posts: 140
    edited January 2005
    Of course, this is a subjective discussion as everyone's sound preferences vary.
    I have an SVS PB12Plus/2 and was trying the same thing that he wants to do. I was running RTi38's for fronts, and when I switched to RTi70's I could tell a big difference in sound. The 70's have a much "fuller" sound with more impact. Both speakers were crossed at 80hz, calibrated the same, and have the same tweeters and drivers.
    VR3 Posts: 29,395
    edited January 2005
    Stacking rocks.
    Buy 2 pairs, stack them. Dont like, return one pair.
  • Sami
    Sami Posts: 4,634
    edited January 2005
    LSi7's with SVS PCU sound very good. Much better than RTi150's with the same sub. I moved the 150's out of my HT and now they are collecting dust.
