Crossover Schematics (Non Vintage)
Hi,
Is there a place to get the crossover schematics for the non-vintage speakers?
Or at least the speakers I have are not in vintage posts.
RTi A9
RTi A3
FXi A4
CSi A6
I asked Polk's CS, but they said as it's a current model, they could not provide it.
Best Answer
Answers
  • I was hoping to know what resistors and caps I would need to buy before having to pull them out. Plan everything in advance to reduce down time.
    pitdogg2 Posts: 27,225
    edited November 2019
    Markardi wrote: »
    Then pull the binding post plate out. You'll have everything you need to know. Honestly it is the best way to know for certain. In the past polk made changes on the fly that were not documented in the schematic they listed until much later or if they ever documented it at all. This will save you from ordering and finding out it was not correct as to what you actually have.
    VR3 Posts: 29,533
    Polks stuff from the last twenty years is very consistent
