Where can I get an SDA SRS 2 Interconnect Wire?
adobeboy
I just inherited a set of SDA SRS 2 speakers but no interconnect wire and Polk no longer sells the wire. Where can I find one online?
https://polksda.com/sdasrs2.shtml?fbclid=IwAR2Y-oa8NlbL43O3X3-hwP9shMxmfYb37j59KARBbCAisMQAAr4Gt8dHMR4
Thanks,
Michael
Thanks,
Michael
Ebay
Looks like you have the pin blade connector. So:
https://www.ebay.com/itm/Interconnect-Cable-Polk-Audio-SDA-SRS2-3-Speakers-others-20ft-Gold-New-Read/163765404762?hash=item26212dc45a:g:zm0AAOSwgPVcwyEj
It only has the pin because I guess the blade isn't necessary. I will let others correct me if this is wrong.
Making your own cable is always a option as well -
Blade is not needed unless you have non-common amplifier. What amp are you using.
I could be wrong but i thought i read some where the "blade" on the pin blade series polks was just to strengthen the connection and doesn't carry a signal ie..just for extra support.
The Pin is ground from each channel so common ground amps will definitely be needed unless you have a ai-1 interface or dreadnaught !
Blade Blade connections ech carry a signal and cannot be used with non common ground amps even with a ai-1 interface or dreadnaught -
Pin Carry's the signal, blade goes to ground internally. (Black binding post)
AI-1 cable and dreadnaught use blade to tie all grounds together to common ground. -
Thx @pitdogg2 Learn something new everyday.I'll stick to plumbing and play with controlling water and poo.
I have never considered attempting anything myself and my personal Tech's have been Trey and Dave!
