DRM Music Converter Software
Anyone here ever use DRM music converter software to convert files from Spotify, Tidal, etc. into FLAC, MP3, etc.?
I've played around with the trial of the Spotify version from DRmare here: https://www.drmare.com/ and it seems to work well. It can convert at up to 48kHz and over 320kbps.
The resulting bit rate seems to depend on the source file. Some that I converted came over at 800-900kbps, and others up to well over 1,000kbps. The trial version will only convert one minute of music, and the FLACs I converted varied in size from ~6-8MB for the one minute tracks. I have Spotify Premium, so not sure if that makes a difference in what bit/sample rates you can get.
Conversion happens at 5X speed, so typical song takes less than a minute to convert. It retains ID tags during the conversion, and also brings in album artwork. You can select individual songs, or choose an entire album or playlist to convert in a batch.
DRmare has a Tidal version as well, but I haven't tried it. They have PC and Mac versions of the software. Spotify version costs $29.95, and Tidal is $34.95.
They have other conversion products as well, including one that converts those pesky M4P files...and practically any other format. That's actually how I found them. I got a new portable DAP that doesn't play M4P files, so I needed something to convert all the old iTunes files from YEARS past.
    Clipdat Posts: 13,101
    Isn't this skirting the fine line of copyright infringement?
  • jdjohn
    jdjohn Posts: 3,426
    Perhaps...but tell me this: do you have to 'subscribe for life' to justify listening to music that you've paid good money to hear online...or have the RIGHT to hear? Of course re-selling downloaded tracks, or using them towards your own profit, is the primary infringement violation...not listening to music that you have paid for THE RIGHT to hear and download.
    And there's the thing - if you download a file to listen 'offline' via their app, why can't you convert the file to another, more universal, format?
    Might want to read Tidal's EULA.
  • Nightfall
    Nightfall Posts: 10,083
    Deja Vu
    afterburnt wrote: »
    Village Idiot of Club Polk
    mhardy6647 Posts: 35,464
    edited November 2019
    Clipdat wrote: »
    Since you brought it up -- I don't think it is "skirting" at all, FWIW. :|
    I believe that the purpose of DRM is to discourage piracy.
    That said.
    1) it's not my place to tell others what to do or not to do.
    2) I reckon that any s/w products that enable copying of copyrighted material that employs DRM will state in their EULAs that it is the end user's responsibility to ensure that all applicable laws and regulations are complied with in the use of the s/w. What the end user does with the conditions of the EULA is a risk management decision. The RIAA (e.g.) is not likely to go after an individual... but it has happened.
    As @Clipdat notes, the EULA of the streaming/download service in question should state what rights the end user has and doesn't have vis-a-vis content hosted on the service. Generally, I thought that one of the benefits (on the supplier side) of the business model of the streaming services is to dissuade end users from copying/downloading the content.
    Even with physical media (CDs & records), one purchases the physical media and a license to use the copyrighted content contained thereupon -- one does not own the content, only the medium.
  • tophatjohnny
    Clipdat wrote: »
  • OleBoot
    OleBoot Posts: 3,135
    Wow, I'd better stop using my DVR before there's a dawn raid.
  • erniejade
    erniejade Posts: 6,321
    @OleBoot Is your dvr owned by the cable company or by you?
    If owned by the cable company, once you stop paying for the service the movie or show goes away. Same as Tidal.
    msg Posts: 10,595
    Clipdat wrote: »
    THJ says, "Hahaha, Amateurs!"
  • OleBoot
    erniejade wrote: »
    It was a mindless joke, but very good point.
  • jdjohn
    jdjohn Posts: 3,426
    So, an honest question: Why would this product still be allowed on the market if it were considered illegal? It's even had a positive review from C/Net FWIW.
    Also, is sharing hi-res files (from whatever source) between forum members an infringement?
  • jdjohn
    jdjohn Posts: 3,426
    I've made my decision, spammer. You make yours.
  • Ashley2060
    Sounds good. I will try it. Thanks.
  • Gardenstater
    Gardenstater Posts: 4,867
    If I recall correctly you can only download TIDAL files with the mobile app but not the desktop one. I'm sure removing the DRM is against the EULA but I don't see any harm in it personally, if you don't share it with anyone else. It is definitely a slippery slope though. They want you to lose access to the files when you discontinue your subs of course. As far as the effect on the artists goes, that would be another question. They probably only get paid once, when you make the download.
    There is another way also. The high res stream can be recorded with programs such as Audials 2016 (I have this), that take the stream after it goes through your kernel mixer of your operating system and copy it. Is it bitperfect? I doubt it because I hear a very slight loss of fidelity or openness so there must be a re-sampling involved. This is legal as far as I know.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    pitdogg2 Posts: 27,689
    Moleeee reported
  • rooftop59
    rooftop59 Posts: 8,120
    Mianji reported
    Game Room 5.1.4:
    Bedroom 2.1
  • freya
    freya Posts: 4
    I have used TunesKit Spotify Music Converter, but I have not used the Tidal converter.
    Regarding the bit rate, it seems that the software you used cannot be adjusted, but TunesKit can be adjusted according to your preferences, including channel and sample rate.
  • jdjohn
    jdjohn Posts: 3,426
    Regardless of the spammer above, I doubt I'll be using this product anymore.
    Spotify disabled my account a couple of days ago for "unauthorized content download". Honestly, I have probably only downloaded maybe a dozen albums over the two years since purchasing the software, with the latest download occurring about two months ago. I'm not sure why just now the flag happened.
    Anyway, once I pinky-promised not to do it anymore, Spotify reinstated my account quickly.
    I contacted the software vendor about it, and they basically just said don't download too many at a time, and it should be fine. Wrong answer!
  • leogood
    I haven't used the one you mentioned. I am tring AMusicSoft Spotify Music Converter. It is good. The sound quality of the converted files is okay.
  • jdjohn
    jdjohn Posts: 3,426
    reported
    Baron reported
  • tonyp063
    tonyp063 Posts: 1,149
  • jdjohn
    jdjohn Posts: 3,426
    edited February 2022
    reported...I wish I had never created this thread...admins can feel free to take it down
  • BlueFox
    BlueFox Posts: 15,250
    LOL. This thread is a spam magnet.
