Looking forward to L800 but have concerns, what are your thoughts?
145791013
  • K_MK_M Posts: 1,537
    soupbone wrote: »
    Remember, dealing with opinions here. But I don't think there is anything you could do to make an older model better than a newly designed L800. That would include changing out every single component.
    Some of us have gotten very close to changing out every single component. In my SDA SRS 1.2TLs, the only stock parts are the 6.5" drivers and the MDF cabinets, and even the cabinets are modified with driver retaining rings.
    Not saying this in an antagonizing way,(even if it comes off that way) but are you alluding to thinking the Original 1980s Midwoofers can not be bettered?
    Lsi15, Lsi9, LsiC,Rta11t,M5jr+,M4, SDA SRS 2.3TL, Rti6....Still listing stuff, a work in progress.
    B+W-Sold
    Electro Voice EV-SIX
    Infinity-Sold
    Advent-Now gone
    Yamaha A-S801
    Yamaha RX-V377
    Yamaha RX-A860
    Yamaha RX-A3060
    Harman Kardon Hk-350i
    Harman Kardon Hk-........
    Harman Kardon PM-665
    Harman Kardon HK-775
    Pioneer.......Stereo Receiver
  • EmlynEmlyn Posts: 2,528
    Any drivers that are designed to a price/performance point can be improved upon. Even current designs. There have been a couple ways in which the Polk midwoofer and passive radiator performance could and have been improved. Namely dampening the stamped metal baskets and better anchoring the drivers to the cabinet structure either with ring supports or inserts for the screws/bolts. Those material changes were very easy to identify by ear. Both of those had very beneficial results for me.
    There was no way I would have kept any Polks with the dead fish eye SL2000 tweeters, so that was another huge area of improvement to correct what came to be perceived as a defect over time.
    1. Polk LSiM707, 704C, 703; Dual SVS SB2000 subwoofers; Marantz SR7011 receiver; Parasound A23 amp; Oppo 205; Sony 65" 4K TV; FIOS; PS Audio Power Plant Premier; MIT S2 cables
    2. JM Labs Electra 920.1; Sonic Frontiers Line 3 Preamp; Classe Model 25 amp; Sony HAP-Z1ES; Oppo 105D; Music Hall MMF7 and Acoustech phono pre; PS Audio Power Director; MIT S1 Cables
    3. Polk LSiM703; Parasound JC2BP and A21; Sony 48" 4K TV; Wyred4Sound DAC 2; Oppo 203; Squeezebox Touch; MIT S3 cables
    edited November 10
    Emlyn wrote: »
    I could swear the SL2000 tweeters aged or sounded worse over time.
    I wonder if Polk realized this and the reason for the replacement "newer" style tweeters.
    Not just the 12.5 kHz peak but something just sounded off about them.
    B+W-Sold
    Infinity-Sold
    Advent-Now gone
    Yamaha A-S801
    Yamaha RX-V377
    Yamaha RX-A860
    Yamaha RX-A3060
  • nooshinjohnnooshinjohn Posts: 21,575
    Emlyn wrote: »
    For their time, doped paper cones were among the best regarded driver materials you could get. They were very carefully researched by Polk to do their job, and were selected despite there being several other driver types that were cheaper. They were also built in-house. Back then, this helped keep costs down.
    Today, there are drivers that are several orders of magnitude better that the MW65xx, but I do t think any of them would work as well in the older Polk speakers. Also keep in mind that some of the more well regarded audiophile speakers made even today use doped appear cones.
    The Gear... Carver "Statement" Mono-blocks, TriangleArt Reference SE with Pass Labs Xono Phono Preamp, Walker Precision Motor Drive, ClearAudio Goldfinger Diamond v2 cartridge and Origin Conquerer Mk3c tonearm, Polk Audio "Signature" Reference Series 1.2TL with complete mods, Pass Labs X0.2 three chassis preamp, PS Audio PerfectWave DAC MkII, Pioneer Elite SC-LX701, Oppo UDP-205 4K Blu-ray player, Sony XBR70x850B 4k, Polk audio AB700/800 "in-wall" surrounds.
    Saying that it's "too hard" to pursue your dreams is no different than admitting to yourself that you are too lazy to achieve them.
    “If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it.”
  • DarqueKnightDarqueKnight Posts: 6,619
    Emlyn wrote: »
    One is the size of the big ones overloading the room I have my two channel system in while also being picky on requiring placement close to the front wall.
    Two things I have never heard better though are the SDA imaging and the way the midwoofers worked with the passive radiators so seamlessly. To me those two factors are what made them so fun to listen to.
    I replaced the SDA SRSs (original) in my home theater with LSiM 707s. I did that strictly for aesthetic reasons. I prefer the look of smaller speakers in that room. The 707s produce a smaller front stage than the SRSs, but they produce a more cohesive front stage with the LSiM 706c center.
    Yes, there have been some substantial advancements in motor structure, basket damping, and materials since the original SDA midwoofers debuted. Some years ago I asked Polk's engineering department for recommendations for upgrade replacements for the original drivers. I was told that different drivers would require a different crossover to properly accommodate the electrical parameters of the new drivers. Cabinet modifications might also be required.
    "So hot it burns Mice!"~DK
    "Polk SDA-SRSs are hopelessly out of date both sonically and technologically... I see no value whatsoever in older SDA speakers."~Audio Asylum Member
    "Knowledge, without understanding, is a path to failure."~DK
    "Those who irrationally rail against something or someone that is no threat to them, actually desire (or desire to be like) the thing or person they are railing against."~DK
  • SIHABSIHAB Posts: 1,578
    It's starting to sound like the L600 is the one to get...
  • pitdogg2pitdogg2 Posts: 14,884
    K_M wrote: »
    Emlyn wrote: »
    Yes I do agree with the bold type.
    I will also remind you in the tweeter shoot out Ray @DarqueKnight had compared he also found the SL1000 to be the better of the two. Both had polyamide domes yet i can agree the SL2000 was much harsher tweeter and I found the domes to not age as well as my much older SL1000 tweeters i have stashed. I can also attest to the SL1000 also having magnet glue problems. Several I have had let loose and locked up the voice coil. So you also have that problem.
  • F1nutF1nut Posts: 43,091
    Comment from an attendee the NY Audio Show.
    Polk Audio / Marantz room - another WOW! Polk were showcasing those new top of the line speakers with cross-talk cancelling technology array on top, driven by a full Marantz stack. Amazing power, detail, and clarity, with no audible distortion even at loud SPL. Color me impressed. Polk people advice pretty close placement: 6 to 8 feet apart, depending on the room, and no toe-in - they need to face the room straight, the array is angled to mimic toe-in, so any additional toe-in done by you will actually ruin the main effect of the speakers, i.e. cross-talk elimination.
  • WLDockWLDock Posts: 2,671
    SIHAB wrote: »
    Who's listened to it?
    FAMILY ROOM
    HDTV - Sharp AQUOS LC-70LE600U 70" | AVR/Streamer - Onkyo TX-NR3008 | Amp - Parasound HCA-1203A
    Blu-Ray/Media/Gaming - Sony PS3-320GB / Microsoft Xbox One | Broadcast - Xfinity X1 Platform
    Front Spkrs - Coming...DIY Statement II | Center Spkrs - Coming...DIY Statement II | Rear Spkrs - Artison Portrait LRS
    Sub - DIY Stereo Integrity HT 15 | Sub Amp - Dayton Audio SA1000
    Wire - Audioquest Type 4, BJC Belden 5000 | HDMI - BJC Belden | Power Cables - Pangea | Surge - Monster
    @WLDock
    Not I. I meant for ease of setup and enjoyment.
    Most people aren't as hard core as we are.
    The L800s, in both finishes, have been available for shipping from Crutchfield for a few days now. They do say low stock. No sign of the L600s yet. All the other speakers in the line are available including the Atmos modules and center channel. That's one big center speaker!
  • mpitogompitogo Posts: 366
    From what I was told they shipped to dealers last Friday. My dealer has them in black but not walnut. Walnut is worth the short wait. Not sure bout online dealers. My dealer will deliver, unbox and setup.
    Living Room Music-2.0 Polk L800 | McIntosh C47 | McIntosh MC452 | Denon DP-2500A | Oppo BDP-103 | iTunes Laptop via USB
    Family Room Home Theater-7.2.2 (Atmos) Polk LSiM 707, 706c, Dual DSW microPRO 3000, LSiM 702 F/X [x4], RC65i | Marantz SR7009 | Rotel RB-1590 [FL/FR] | Sony UBP-X800 4K | Xbox One S 4K | AppleTV 4K | HTPC | Sony 75” XBR X850D 4K
    Office Home Theater-5.1 Polk RT55, CS400, PSW450, f/x 500 | Onkyo TX-SR705 | Xbox 360 MCE | AppleTV | Samsung 55”
    Office Music-2.0 KEF Q100 | Sansui AU-6900 | Topping DX7s | Sansui FR-1080
    Master Bedroom Music-2.0 Totem Hawk | McIntosh MA-5200
    Patio Music-2.0 Polk Atrium8 | AMC 2445 bridged
    Airplay zones: Family Room (HDMI), Master Bedroom (Optical), Office (HDMI), Living Room (Optical), SR7009 (AVR direct) and Patio (analog). MacMini iTunes multi-stream to any, combo or all.
    Spares: Polk LSi25, LSiC, CS300, T15, Martin Logan Motion 40, Klipsch RP-600M, Dynamo 500, Rotel RA-1570, Denon AVR-4802R, Onkyo DX-C540, DVP-S500D, PS HX-500, PASS ACA (kit) Class A balanced monoblocks
    Maintenance: Pro-Ject VC-S Record Cleaning Machine
  • DSkipDSkip Posts: 16,282
    mpitogo wrote: »
    I hope you enjoy the hell out of them. There is a lot to like about them.
  • ESavinonESavinon SRT Specialist Posts: 3,011
    Heard them at the NY Audio show.
    The L800 are definetly among the best SDA speakers made!
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • dromundsdromunds Posts: 8,362
    ESavinon wrote: »
    Would you please expound ?
    L600s in black now available for shipping from Crutchfield...
    https://www.crutchfield.com/p_107L600BA/Polk-Audio-Legend-L600-Black-Ash.html
  • BlueFoxBlueFox Posts: 12,255
    Are they $2000 for a pair, or $4000 per pair?
    Bud - Silicon Valley
    Lumin X1
    Sony XA-5400ES SACD
    Pass XP-22 pre, X600.5 amps
    Magico S5 MKII Mcast Rose speakers, SPOD spikes
    Shunyata Triton v3/Typhon QR on preamp, Denali 2000 (2) on amps
  • ptrooperptrooper Posts: 320
    Down the bottom there it says " each"
    well the L800 is 6K so those should be 4K a pair
    ptrooper wrote: »
    Yes, but L800 says $6K each, but that means a pair.
    Lumin X1
    Sony XA-5400ES SACD
    edited November 13
    I see they have included this recommendation, bravo!
    high-current amplification from a quality power amp or integrated amplifier is recommended for best performance
    edited November 13
    They'll have to stick to their advertising....buy up now!
    Its a bargain but i do beleive you'r dreaming!
    BlueFox wrote: »
    ptrooper wrote: »
    edited November 14
    Dam,If only there were two i the pic! ;) end of convo...
    "Really Looking forward to the reviews from the owners of the L800's soon!
    The local west coast hifi shop in the Malaga area here down under in Perth will have L600's for a few days,I'll be there.
    Interdyne the suppler for Polk here are only supplying these for a demo to suppliers.
  • verbverb Posts: 8,174
    mpitogo wrote: »
    Polk Audio L800 Walnut in the house!
    WOW! But seriously talk to me in 100 hours. These are just FOOTB. Compares well to LSiM 707's which were previously my favorite.
    Will pictures soon.
    Congrats on being the first! Looking forward to pics and your impressions!
    Basement: Polk SDA SRS, Cary SLP-05 Pre, Enlightened Audio Designs CD Transport, Northstar Designs Excelsio DAC, Silnote Morpheus Ref2 Digital Cable, Marantz SA-14 SACD, McIntosh MC300 Amp, Furman 15PFi Power Conditioner, Pangea Power Cables, Wireworld Oasis 8 RCA IC's, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
    Office: PC, EAR Acute CD Player, EAR 834L Pre, PASS ACA Monoblocks, Denon UDR-F10 Cassette, Acoustic Technologies Classic FR Speakers, SVS SB12 Plus sub, MIT AVt2 speaker cables, IFI Purifier2, AQ Cinnamon USB cable, Groneberg Quatro Reference IC's
    Spare Room: , Antique Sound Labs Wave AV-8 Monoblocks, Tisbury Mini Passive Pre, Tjoeb 99 tube CD player (modified Marantz CD-38), Analysis Plus Oval 9's, Zu Jumpers, AudioEngine B1 Streamer, Klipsch RB-61 v2, SVS PB1000 sub, Blue Jeans RCA IC's
    Living Room: Peachtree Nova Integrated, Cambridge CXN v2 Streamer, Furman 15PFi Power Conditioner, Polk RT265 In Wall Speakers, Polk DSW Pro 660wi sub
  • mhardy6647mhardy6647 Posts: 23,564
    mpitogo wrote: »
    Pictures for now. On my phone it is correct. Just trim your head...😜
    [emphasis added]
    man-o-man, autocorrect is not your friend!
    ... meanwhile, back at the ranch.
    il n'y a pas de quoi.
    edited November 15
  • monepolkmonepolk Posts: 1,045
    Very nice. Looking forward to your impressions. Especially since some of your equipment looks VERY familiar :)
Howdy, Stranger!
