Which box to put a 12'' woofer and other important ??
duane26
I was looking at the Q-Logic QLH-.8512se for the MM2124, any thoughts? Absolutly no way I am building one. Is this a good MDF box for $65?
http://www.cardomain.com/item/QLCQLH8512SE?ref=prgr
Is .85 cu. ft. close enough to polk's recomendation .88?
How would I go about instaling a box in the trunk of my 00' civic si coupe? Is there special brackets or something to keep it in place? I love taking quick turns.
Also, I was going to go with a 4 gauge streetwires kit for my amplifier, MTX Thunder 684, is this a good choice or should I go with Fosgate, lightning, phoenix gold, stinger?
Thank-You for your time!
Post edited by duane26 on
the box should stay in place, if not you can get some heavy duty velcro and it wont budge. for amp kits id recommend knukonceptz.com
great stuff and an even better price
Streetwires, Stinger, Knuconceptz, Tsunami are all very good wire. Youll do fine going with any of them. Just dont use Monster Cable.
As long as that !-Logic box is ALL MDF and no plastic it will be fine.polkaudio sound quality competitor since 2005
ok. look this answer, ===> www.s_car_mix_i.ukTesting
Testing
Testing -
Looks like we've got a bot on here.
This is the 4th stupid link on here. Somebody need to zap his IP address.polkaudio sound quality competitor since 2005
