More power!
I had an electrician in a few weeks ago to do some work and we discussed installing a dedicated 20amp outlet for the home theater. He's recommending a 4 outlet 20amp line with the surge protecting inside the breaker box. I'm not up on all the options out there and figured i'd see what route y'all may have taken.
I have a new (8 months) Denon receiver capable of doing 7 channels plus 4 ceiling. Since the receiver can't handle loads down to 4ohm (only 8 and 6ohm), I had to put my vintage Carver m1.5t amp into the preamp outs to handle the LSi 25's. The receiver would cut off into protection mode when not even being pushed very hard. Then I have my SVS PC-Ultra added in there along with the TV, OPPO BR player, Apple TV...and you can see how I need something way more beefy. I'll probably put the Carver amp, Denon receiver and SVS sub into the 20amp outlet, then keep the TV and other items into the current outlet.
So, what y'all got supplying juice to your rigs?
No excuses!
  • rpf65rpf65 Posts: 2,113
    I have 4 dedicated 20 amp outlets. One for sources, one for subs, and one will be for each amp, when I get the funds to buy the second one.
  • EndersShadowEndersShadow Posts: 17,035
    edited October 2019
    @lightman1
    I have 3 Dedicated 20 amp circuits.
    1. APC H15 + source gear, AVR, and Plasma TV
    2. B&K 200.5
    3. 2 Crown XLS2000 and some other sub amps
  • F1nutF1nut Posts: 43,622
    John, for all that gear run 2 dedicated 20 amp 10 gauge lines. Don't let the electrician tell you 12 gauge is enough. Don't forget to upgrade the outlets.
  • daddyjtdaddyjt Posts: 1,168
    I just wired for my 2ch rig. I ran a 10ga 20a line for the Mark Levinson, and a 12ga 20a line for the source and pre, and any other do-dads.
    Too much stuff to keep track of.
    Currently enjoying: Legacy Focus 20/20, McCormack DNA 225, Bill D C1, Oppo 105
  • motorstereomotorstereo Posts: 1,396
    3 20amp dedicated circuits here using 10 gauge spiral wound wire with the boxes wired very close to the breaker panel. Checking to see which 120 leg of your panel is the quietest is very important to. In my case the difference was substantial and noticeable when I switched to the quieter leg after unknowingly using the noisier one for many years
  • I have 2 20amp dedicated lines and do take the advice of at least hospital grade outlets. Was an amazing upgrade to both of my rigs.
  • mhardy6647mhardy6647 Posts: 24,543
    My experience with electricians is that they'll do whatever you ask 'em -- as long as you're willing to pay for it.
  • ZLTFULZLTFUL Posts: 5,233
    Look at all yer cute lil 20 amp circuits.
    Theater has 3 dedicated 30 amp circuits for the media gear, amplifiers and processing.
    Then 2 20 amp lines for seating and general use and then a 15 amp for lighting.
  • CH46ECH46E Posts: 1,762
    I would certainly go with 10 awg Romex. I also went with a heavy duty Levitron outlet. Anything plugged into it fits very tight.
  • verbverb Posts: 9,038
    Interesting thread, as I plan to run some dedicated lines in the basement.
    @Strong Bad what type of surge protectors are you planning to use? IIRC I read somewhere some designs may a bit noisy.
    Basement: Polk SDA SRS,Cary SLP-05 Pre,Enlightened Audio Designs CD Transport,Northstar Designs Excelsio DAC,Cambridge 851N streamer,Marantz SA-14 SACD,McIntosh MC300 Amp,Silnote Morpheus Ref2 Digital Cable,Furman 15PFi Power Conditioner,Pangea Power Cables,Wireworld Oasis 8 RCA IC's,MIT Shotgun S3 IC's,MIT Shotgun S1 Bi-Wire speaker cables
    Office: PC,EAR Acute CD Player,EAR 834L Pre,Northstar Designs Intenso DAC,PASS ACA Monoblocks,Denon UDR-F10 Cassette,Acoustic Technologies Classic FR Speakers,SVS SB12 Plus sub,MIT AVt2 speaker cables,IFI Purifier2,AQ Cinnamon USB cable,Groneberg Quatro Reference IC's
    Spare Room: Antique Sound Labs Wave AV-8 Monoblocks,Tisbury Mini Passive Pre,Tjoeb 99 tube CD player (modified Marantz CD-38),Analysis Plus Oval 9's,Zu Jumpers,AudioEngine B1 Streamer,Klipsch RB-61 v2,SVS PB1000 sub,Blue Jeans RCA IC's
    Living Room: Peachtree Nova Integrated,Cambridge CXN v2 Streamer,Rotel RCD-1072 CD player,Furman 15PFi Power Conditioner,Polk RT265 In Wall Speakers,Polk DSW Pro 660wi sub
  • polrbehrpolrbehr Posts: 2,471
    ZLTFUL wrote: »
    Or, you could have 2 electric dryers and an electric cook top going... LOL
    Seriously, I always found it difficult to wrap solid 10awg around the screws in a typical
    outlet, even one designed for 20 amps. What kind of outlets do you use?
  • mrlorenmrloren Posts: 2,220
    Gee I wish I could get a 20a ran to my HT. I did have a couple quotes and it was way too much.
    I currently have all my gear on the stock15a circuit. Haven't blown the yet and I have cranked it up. When I changed my outlets my house is wired with 12awg wire.
    Family Room:
    Samsung UN75RU710DFXZA,
    Denon AVR-X4400H, Emotiva XPA3 GEN3
    Oppo BDP-93,Sony UBP-X800BM, WD Live HUB.
    Main: Polk LsiM 705
    Center: Polk LSiM 704C
    Front High/Rear High In-Ceiling Polk 80F/X RT
    Surrounds: Polk S15
    Sub: HSU VTF3-MK5
    Bed Room;
    Marantz SR5010, BDP-S270
    Main: Polk Signature S20
    Center: Polk Signature S35
    Rear: Polk R15
    Sub: HSU STF-2
    Working Warehouse;
    Sony 2100ES AVR, Sony DVP-NS3100ES for disc
    Cerwin Vega AT-12 (blasters) Advent Prodigy (listening)
    Old sony 12" Sub
    Mini tower PC with 400GB of music
  • DaveHoDaveHo Posts: 2,525
    polrbehr wrote: »
    ZLTFUL wrote: »
    Back clamp are the way to go. NOT backstab which are a completely different and useless animal.
  • SCompRacerSCompRacer Posts: 7,195
    I have two 20 amp circuits for the two channel. One for the amp, which pulls 13 amps at idle and one for the rest of the gear.
    Make yourself necessary to someone. Ralph Waldo Emerson
    Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ & Pro 11+ * Signature Series Sonore Music Server w/Deux PS* Twisted Pear Buffalo III Dual Mono ESS Sabre32 DAC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
  • pitdogg2pitdogg2 Posts: 15,562
    DaveHo wrote: »
    polrbehr wrote: »
    ZLTFUL wrote: »
    I'd be very surprised if any of those are still sold. From my recollection many had arcing problems from the cheap brass strip that would lose tension from repeatedly hot cold cycles. I've removed plenty that had soot marks.
    polrbehr wrote: »
    ZLTFUL wrote: »
    Using true 30a twist lock outlets to the pure sine wave UPSes/regenerators.
    Ran 8/2 copper to all 3. All of the 20a circuits are 10/2 copper and the 15a circuits are all 12/2 copper.
    I also have 2 20a circuits in my office for the 2 channel and a third 20a circuit for the remaining outlets in there for work computer and general use. I have a 15a general use UPS covered outlet for the network cabinet in my office.
  • joecoulsonjoecoulson Posts: 4,109
    SCompRacer wrote: »
    13 amps at idle. What does it run on?!? Red matter?
    Auralic Vega G1/Rega TT/Denon SACD - Parasound P6 - PS Audio M700x2 - Elac Adante AF-61 - AQ Niagara 5000 - SVS SB16u
    joecoulson wrote: »
    SCompRacer wrote: »
    parts of it can get 300°+. It's definitely A HE MAN AMP.
    Class A all the way!
  • gp4jesusgp4jesus Posts: 1,343
    Don’t short change your system’s power feed.
    Presently 3 dedicated 20As - I wish I ran 4. One feeds the APC H15 for the low power stuff. The other two feed the the amps and subs.
    Taking my cue from somebody on this forum: when I relocate my system, I will start w/a system dedicated breaker panel w/internal surge suppression. I anticipate 5 or 6* dedicated circuits to power additional upgrades: two more channels, several more amps, & two more subs.
    * final still pending
    Samsung 60" UN60ES6100 LED
    Outlaw Audio 976 Pre/Pro
    Samsung BDP, DirecTV Rcvr, Xbox, Phillips CD chgr
    Canare 14 ga - LCR tweeters inside*; CC outside
    BJC 10 ga - LCR mids, inside* & out
    8 ga Powerline - LR woofers, inside* & out
    *soldered
    LR: tri-amped RTi A7 w/Rotels. Woofers - 980BX; M&T - 981
    CC: Rotel RB985 -> tri-amped CSi A6
    5 Audio Pro Subs: 1 B1.39: an Evidence at each corner
    Surrounds: Rotel 981 -> AR 12 ga -> RTi A3
    3 dedicated 20A feeds; APC H15; 4 Furman Miniport 20s
  • gp4jesus wrote: »
    Amen to don't short short change your rigs. One of the least expensive (in the scheme of things? Upgrades yet most dodged ..for whatever the excuses may be? I'm saying this simple upgrade gave both of my mediocre rigs a boost to where they both sound very nice. If you don't have a dedicated line to your gear you are simply half stepping and maybe a quick listen to Heatwave's "ain't no half steppin" will motivate ya😂😂🎩
    Another thing is to keep those circuits on the same 120 leg. Checking to see which leg is quieter with one of these meters is also a good idea. In my case my 2 legs were vastly different and provided me with a nice upgrade when I switched to the quieter 120 leg.
    Pretty cool little gadget. Interesting that there are a couple of companies out there putting their own brand name on it and almost charging double! :)
    Even more interesting. Alpha labs claim that their unit is made in the USA !?! :)
    edited November 2019
    Yes the Alpha Labs is the unit I own and it is made in Utah. FWIW that 1152 number shown is high (a lower number is better) and is audible (probably an led dimmer). Most of my lines normally run about half that
    But here's what dedicated lines on the quietest 120 leg coupled with a good pc can do to those numbers before they power my rig
    Very nice! I was wondering about those knock-offs! I'll stick with made in the USA! :)
  • ClipdatClipdat Posts: 7,560
    Dave if you get one send it over when you're done so I can try it out on my power line and then send it back to you.
    "Electronic music is human sound adapting to indulge technology, and for some, it feels like the signature sound of energy. New and abstract sounds over hypnotic rhythms can conjure vast soundscapes for escape, pleasure, and transcendence."
    Clipdat wrote: »
    Will do! :)
  • Strong BadStrong Bad Posts: 4,226
    I appreciate the comments and suggestions. I contacted the Electrician and said i'd like to go with TWO dedicated 20amp outlets. Thats going to be done the last Saturday of this month.
    Going to be interesting to see what improvements this makes to the home theater, especially with the SVS sub and the Carver m1.5t amp.
    "UNLIMITED POWER!!!!" - Darth Sideous
    No excuses!
    Just ordered one. Directly from Alpha Labs!
    verb wrote: »
    Nice - perhaps you could do a sort of “demo” program, similar to the new speakers going around. And each member that gets it sends you $10 PP or so to offset the cost, and pays shipping to the next member:-)
Howdy, Stranger!
