Sda compact crossover problem
Hello everyone,,
Iam new at working on speakers.One mid and tweeter are not working on each. I have tested the woofer and tweeter on each speaker and they work.I believe the top crossover is the problem on each speaker.Do I need to replace all caps and the resister? Any advice would be great.This model has 2 mids and 2 tweeter and the passive woofer.
  • F1nutF1nut Posts: 42,956
    Do you have the SDA cable connected?
    Guess we'll never know.
  • civiliancivilian Posts: 299
    He hooked it up, it sounded great and he forgot to post back the results. :D
    ________________
    2 Channel-SDA 2.3TL's
    5.1-RT3000P's/CS1000P/RT2000P's/Denon AVR-4520
Howdy, Stranger!
