Looking for small center speaker
I am currently using RT55 fronts and R10 rear speakers in my home theater setup. (The receiver is a Yamaha HTR-5150. No sub.) I have a CS300 center but am not using it due to fit issues. With the current setup it is difficult in some movies to hear dialog without the louder portions being too loud. Would adding a small center channel speaker help? I only have about 6 inches of height and 7 inches of depth below the TV to work with. I am looking at the Definitive Technology ProCenter 1000. Would that speaker be a close enough match to the RT55s? Alternatives?
  • rooftop59
    rooftop59 Posts: 8,120
    That’s a good center for the size. I ran it for a while with promonitor 800s in the main living room HT and with a good sub I was surprised how effective it was. The timbre will be slightly different but unless you are listening to lots of concert blu rays or multi channel SACDs I don’t think it will bother you. And if you buy a used one you can just resell it if you decide you don’t like it...
    Game Room 5.1.4:
    Bedroom 2.1
  • Tom55
    Tom55 Posts: 3
    I did get the Definitive Technology ProCenter 1000. I'm running with a couple of dB boost on the center channel and decreasing the overall volume level. This keeps the peak volume somewhat less loud than the no center set up. I haven't noticed the mismatch between the center and mains for movies. (I switch to 2 channel for music.)
  • Interesting. I have a phantom center setup in one of my rooms, and I have no dialogue problems. Are you sure your amp was configured to run a phantom center?
    Main: Polk Rti-38
    Center: Polk Csi-40
    Rear: Polk Fxi-30
    Sub: SVS PB10-isd
    Receiver: Marantz SR-5007
    Buttkicker Mini Concert x 4
  • Nightfall
    Nightfall Posts: 10,083
    edited October 2019
    That's because movies have actual dynamics. What AVR are you running? I know when I was using a Yamaha Aventage you could "boost" dialog which I'm pretty sure was just an EQ that turned up the mid-range but it worked well. It also had some type of night time mode that would limit dynamic range.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Tom55
    Tom55 Posts: 3
    When I was running without a center, I had center speaker set to "none" which routes the center channel to the mains. The receiver (Yamaha HTR-5150) doesn't have a boost for dialog. There is a setting to limit the dynamic range (for Dolby Digital only) but the difference in volume between the dialog and the loudest parts of some movies was still too great. Since most dialog is in the center channel and "action sequences" are in the mains (or distributed across all of the speakers), adding the center allows for lower peak levels by turning the overall volume down while the boost to the center keeps the volume on the dialog high enough. The result may not be exactly what the movie director intended, but it is a modest improvement (at least to me). Note: It is more effective for some movies than others.
