7.2.4 setup advice
winchester
Hey guys need some advice on this setup.
My room size is 20x20x10 ft
My setup will include
Pair of rtia9
Csia6
4 svs elevation speakers for atmos
dual hts 12 subwoofers
About the surrounds I am confused which one to buy ( rtia7,rtia5,rtia3 or fxia6)
And I will power my fronts from an external amplifier the rest will be powered by yamaha rx-A3080
Pair of rtia9
Csia6
Welcome to Club Polk. Get the FxiA6 for surrounds. Nice system, enjoy.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Ok @cfrizz
For the sides and as well for the rears ? -
and thank you
Atmos doesn’t like bipolar surrounds. I would just save some coin and get RTi A1s.
Sounds like a great setup! But if you haven’t bought the subs yet, I would look at one svs or hsuLiving Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
@rooftop59 oh ok Yes I haven't bought the subs yet, and what about the RTi A3s ?
As looking at the front setup should I go for the rti a3s as surrounds @rooftop59
As polk recommends rtia9 with rtia3
Specially need your advice on this as this will be my first home theatre setup -
winchester wrote: »As looking at the front setup should I go for the rti a3s as surrounds @rooftop59
With that many speakers I think that the A1s would be more than adequate, and that way you could invest more in the sub. That's a BIG room to pressurize. This sub should do the job: http://www.hsuresearch.com/products/vtf-15hmk2.htmlLiving Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
@rooftop59 Thank you sir I will definitely buy this subwoofer
@rooftop59 As you said earlier atmos doesn't like bipolar surrounds can I use one pair of FxiA6 as side surrounds ( dipolar) ? And the rtia1 as rear surrounds
Sorry to bother you again @rooftop59 on this matter. This will be my first setup
Thank you @rooftop59
