No sound from TV?
Classic55
Omni SB1 connected to Samsung TV via optics cable. Turn on to watch TV and the Soundbar LED flashes red for about 10 seconds then turns solid blue and white
Best Answer
Thank you, I will give that a try
Answers
Do the TV speakers work?Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
With my Klipsch 'Sixes' I had to change the TV sound setting to "PCM" in the menu to get the Toslink to work.Carver M4.0t, M1.0t, M200t, TX2, C1, C2, Marantz 2230, 2010, 4070, 1030, APPJ 2013, Rega Brio, Marantz Imperial 7's, Klipsch Heresy III, Quartets, KG4's, KG1's, 'The Sixes', R-12SW, Polk SDA 2a's, Monitor 7cTL's, SDA CRS's, 4a's, Zu Audio Dirty Weekends, Pro-ject Acryl TT, Cambridge 851N, 351C, Panamax 5300PM
Are TV Speakers Working?
I have also experienced it my Sony Bravia television, I can't fix and so I ask my friend for help. He has replaced the speaker unit of the home theater and luckily it did work.A web content writer at PetStreetMall, a place to find quality and affordable pet supplies.
