wow i get my 2 mm2124 in home :) what abt the Enclosure?
SamSagaZ
hey guys, i have an pair of mm2124 in home, after read the manual i see that recomends .88 cu ft for the subwoofers, is that ok?
i will get the best sound using that amount?
after i read the subs plans on the web i dont see any plan to use 2 drivers in sealed box... how i will reach the best sound using sealed, bandpass or ported?
thanks
thanks
Post edited by SamSagaZ on
If the manual calls for .88 ft3 then thats what they will work best in.
Polk subs seem to work much better in sealed boxes built to spec.polkaudio sound quality competitor since 2005
thanks
mm i have problems to build the enclosure, can someone tellme the right size of each mdf panel?
my english is not good and i dont understand very well what the Manual Say... Btw, i made some calcs and i get that my box will be 81lts!!!! its too much right? for 2 mm2124 -
i need an box of 25L for each Sub right?
