Anyone else having problems streaming SiriusXM ?
gyosa
gyosa Posts: 770
2 days now , won’t stay connected for more than a few minutes ?
Using a Yamaha wxc-50.
All other streaming services work fine , tidal , Spotify etc ....
Bk
PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
  • xsmi
    xsmi Posts: 1,804
    I’ve had problems in my car. The music for the current channel plays, but none of the labels for the channels are present. The channels can’t be changed either. This last for about 2mins at a time off and on.
    2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • gyosa
    gyosa Posts: 770
    Talked to yamaha tech support ...
    Many people are having the same problem.
    They’re looking into it .... maybe siriusxm changed their codec or it’s a server problem...
    Bk
  • Irrenhaus
    Irrenhaus Posts: 1,105
    Any new cell towers near you?
    That it has been a problem with XM and T-Mobile towers. Do a search. I have XM on my car and it cuts out and is always near a cell tower. Even on a clear line of sight on a empty road.
    https://sirius-xm-radio.pissedconsumer.com/no-reception-near-cell-towers-201702281014974.html
    Cheers
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • Romo11
    Romo11 Posts: 101
    I've been having problems on my Yamaha AVR and Sirius XM for the past few days.
  • gyosa
    gyosa Posts: 770
    Yep ...
    Hope they fix it ...
    Bk
    Romo11 wrote: »
