Showcase your setups
11213141618
  • steveinazsteveinaz Posts: 19,054
    edited March 2
    New Bluesound Node 2i in place. Sorry for the grainy pic, apparently Ipad 4 doesn't have a flash....below it is my WD Hard drive.
  • Joey_VJoey_V Posts: 7,078
    How’s the node Steve?
    Joey's Gear:
    Current Gear:
    Torus RM15 -> Emm Labs DAC2x and TSDX Transport -> Cary SLP-05 preamp -> Boulder 2060 stereo amp (w/ Audioquest WEL Signature) -> new speakers
    Rotel RA1592 Super Integrated -> Sonus Faber Olympica 3
    Rotel RC1570 preamp -> Rotel RB1582 amp -> Focal Kanta 2
    Old Gear:
    Speakers: BW PM1 (3.5/5), CM10s2 (3.75/5), BW800D3 (5/5), Rockport Aviors (5/5), Sonus Faber Stradivari (5/5), BW 802D2 (4.5/5), Martin Logan Summits (4.25/5), Martin Logan Vantage (4/5), Sonus Faber Cremona Auditor (3.75/5), AV123 Strata Mini (3.5/5), ML Mosaic (3.25/5), Onix Ref1 (3/5), Sonus Faber Concerto (2.75/5), SF Concertino (2.5/5), Axiom M22ti (2/5), Polk LSi9 (3/5), LSi7 (2.9/5)
    Source: Squeezebox 3 -> PS Audio Digital Link III -> Cary 306/200 CDP -> Cary 306 SACD -> EMM LABS DAC2X/TSDX
    Preamplification: Rotel RC1070 -> Rogue Perseus -> Cary SLP98 -> Cary SLP98F1 -> Cary SLP05 (sold and then repurchased)
    Amplification: HK AVR330 -> Rotel RB1070 -> Rotel RB1090 -> Plinius SA102 -> Cary 211FE -> Classe M600 -> Boulder 2060
    Subwoofer: Infinity Entra2 sub -> SVS 25-31PC+ sub
    Joey_V wrote: »
    I like it a lot.
  • maxwardmaxward Posts: 395
    Beautiful speakers and stands.
    Thorens TD-160C; Sumiko Talisman S; Jolida JD9; Marantz CD-53; North Star Intenso;
    Joule-Electra LA-100; Balanced Power Technology AC conditioner;
    Odyssey Khartago monos (with most factory upgrades); Magnepan MG 3.6R
  • cfrizzcfrizz Posts: 13,420
    Beautiful set up Mikey.
    Marantz AV-7705 PrePro, Classé 5 ch. 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony Bravia KDL-40R510C TV, Polk S60 Main Speakers, Boston VR-920 Center Channel, SVS NSD-12 SB12 Subwoofer, Polk DSW 400 Subwoofer, Polk FXi-3 Surround Speakers
  • nooshinjohnnooshinjohn Posts: 21,454
    joecoulson wrote: »
    Update with the AQ Niagara setup and the side rack removed
    Nice aquarium.
    The Gear... Carver "Statement" Mono-blocks, TriangleArt Reference SE with Pass Labs Xono Phono Preamp, Walker Precision Motor Drive, ClearAudio Goldfinger Diamond v2 cartridge and Origin Conquerer Mk3c tonearm, Polk Audio "Signature" Reference Series 1.2TL with complete mods, Pass Labs X0.2 three chassis preamp, PS Audio PerfectWave DAC MkII, Pioneer Elite SC-LX701, Oppo UDP-205 4K Blu-ray player, Sony XBR70x850B 4k, Polk audio AB700/800 "in-wall" surrounds.
    Saying that it's "too hard" to pursue your dreams is no different than admitting to yourself that you are too lazy to achieve them.
    “If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it.”
  • joecoulsonjoecoulson Posts: 3,563
    Lol. Thank You John.
    Auralic Vega G1/Rega TT/Denon SACD - Parasound P6 - PS Audio M700x2 - Elac Adante AF-61
    Ok. I’m tired of the Niagara sitting out. Time for what looks like a simple move, but it’s not.
    Moving everything around inside the cabinet to fit all gear. The Auralic will go on top as it’s beautiful and needs to be showcased.
    Before pics, after to come later.
    Step 2
  • ManticoreManticore Posts: 405
    /\/\/\ That looks much better ;) ;)
    Denon AVR X4200W
    Parasound A23 amplifier
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Denon DP 3000 turntable
    Saec 308sx tonearm w/
    Dynavector 10x5 cart
    Vincent PHO 701 Phono Preamp
    MIT Avt3 Speaker c's
    Audio Quest Big Sur ic's
    Polk SDA 1C's modded
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Polk DSW PRO 440wi sub
    Infinity bu2 sub
    "The early Klingon gets the Gagh"
  • Tony MTony M Posts: 8,351
    edited June 29
    Looks like "50 shades of Coulson". :D
    edited June 29
    Cable management is going to be your nightmare.
  • SCompRacerSCompRacer Posts: 7,190
    edited June 29
    joecoulson wrote: »
    Step 2
    Get yourself some grating, nylon bushings (available in various diameters and lengths) and use zip ties to secure. You can even trim cables to exact length if desired.
    You can also use thin wall plastic pipe (not schedule 40), slit it if you have to, use 45 and 90 degree fittings (you can slit them and re-glue together) and cover with techflex.
    Make yourself necessary to someone. Ralph Waldo Emerson
    Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ & Pro 11+ * Signature Series Sonore Music Server w/Deux PS* Twisted Pear Buffalo III Dual Mono ESS Sabre32 DAC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
    Knee deep now.
    Very neat and tidy Rich!!
    Nearing the end
  • VR3VR3 Posts: 23,455
    Seeing these pictures reminds me why I built an in wall rack with closed doors... Wiring everything is a breeze because it's all back to back
    - Not Tom
    Vr3Mods.com ///// Version3Audio.com
    "No, that's silly talk. Dude, you can't possibly be this audio dumb so quit the act." - Doro
    Last steps
    Looking good
    - Not Tom
  • txcoastal1txcoastal1 Posts: 10,610
    Time for a rootbeer and music
    Dayum right!!
    edited June 29
    And oh man do they sound so much better closer together.
    Audio nirvana right now.
    Edit : not proofreading
    Post edited by joecoulson on
  • corticocortico Posts: 589
    edited June 29
    Nice rigs guys! Here mine late 90’s John Curl Designed Parasound rig, HCA2200II pairs great with the PLD2000, MIT cable loom and Polk Audio LS70... sounds pretty sweet!!
  • verbverb Posts: 7,933
    VR3 wrote: »
    Did you ever post any pics?
    Basement: Polk SDA SRS, Cary SLP-05 Pre, Enlightened Audio Designs CD Transport, Northstar Designs Excelsio DAC, Silnote Morpheus Ref2 Digital Cable, Marantz SA-14 SACD, McIntosh MC300 Amp, Furman 15PFi Power Conditioner, Pangea Power Cables, Wireworld Oasis 8 RCA IC's, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
    Office: PC, EAR Acute CD Player, EAR 834L Pre, PASS ACA Monoblocks, Denon UDR-F10 Cassette, Acoustic Technologies Classic FR Speakers, SVS SB12 Plus sub, MIT AVt2 speaker cables, IFI Purifier2, AQ Cinnamon USB cable, Groneberg Quatro Reference IC's
    Spare Room: , Antique Sound Labs Wave AV-8 Monoblocks, Tisbury Mini Passive Pre, Tjoeb 99 tube CD player (modified Marantz CD-38), Analysis Plus Oval 9's, Zu Jumpers, AudioEngine B1 Streamer, Klipsch RB-61 v2, SVS PB1000 sub, Blue Jeans RCA IC's
    Living Room: Peachtree Nova Integrated, Cambridge CXN v2 Streamer, Furman 15PFi Power Conditioner, Polk RT265 In Wall Speakers, Polk DSW Pro 660wi sub
    edited June 29
    stevep wrote: »
    Not sure if this was an upgrade or not. I really liked my Emotiva Airmotiv 5 powered monitors but they sound quite different from how these are. None of the air and strong imaging that I was expecting based on those and the Stealth 8's I'd heard before. I'm thinking I should have just upgraded the crossovers in the 11TL's instead.
    Before:
    After:
    Wow that is one big center channel. Very nice set up, give your ears time to get used to the new sound! And put the grills on, it will look much nicer, and take another pic with them on.
Howdy, Stranger!
