707 crossovers in a 705
I happen to get my hands on a set of 707 crossovers and was wondering how they would fit in a pair of 705's. I just don't know if they match up
  • WLDock
    WLDock Posts: 3,073
    The 705's have a 2800Hz & 100Hz crossover w/ 5" midrange & 5"x7" woofers.
    The 707's have a 3000Hz & 100Hz crossover w/ 6.5" midrange & 6"x9" woofers
    Given that the speakers are still in production and parts are available from Polk I guess I don't see the point. Whats wrong with your LSiM 705 crossovers? Or are you looking to keep the original crossovers in tack yet have a second set of crossovers to mod? I guess you could use the 707 boards or make your own. Are you planning to build with better components?
    F1nut Posts: 51,751
    Different circuits designed specifically for each model, so no. If you want to improve the 705's upgrade the crossover components.
  • jghglofer
    jghglofer Posts: 100
    I like the 705's just the way they are. but got a set of 707 boards and was just wondering. maybe I will start me a project.
  • rooftop59
    rooftop59 Posts: 8,121
    jghglofer wrote: »
    What exactly are you wondering? The 707s don't have better components, just different specs designed for different drivers and cabinet volume. follow F1NUT's advice...
    But hey they are your speakers and your time and money, have at it!
    Game Room 5.1.4:
    Bedroom 2.1
  • WLDock
    WLDock Posts: 3,073
    edited June 2019
    jghglofer wrote: »
    Ok, your reply is a little vague however maybe you are saying that your goal is to use this set of 707 boards to modify them with better components in hopes of improving the 705's. The boards may or may not work depending on how far you go with the crossover mod. Some of the poly caps from Clarity Caps for example might be much larger and may not fit.
    The best thing to do is to find a schematic but i don't think they were ever released. So, compare the 705 to the 707 crossover side by side to see what the component value differences are. You might have to measure the inductors as they might not be labeled like the caps, and resistors. Both speakers/crossovers seem to use the same topology so there might be minor component changes. However, there could be some changes here and there that one has and the other does not. You can modify the components on the 707 board to the same values as the 705.
    Here are pics of the 705 crossovers.
  • jghglofer
    @WLDock yes your right I did leave the table with out answering. my question was would the 707 boards sound any better in the 705's and that question was answered.
    I am not going to mod the 705's like I said I like them just the way they are. the project will be to use these 707 boards in a build.
  • WLDock
    WLDock Posts: 3,073
    edited June 2019
    jghglofer wrote: »
    Did you get the boards for free or super cheap or something? Because there are tons of DIY project plans out there. Money could be better spent towards the correct components for a given project.
    https://www.audioholics.com/diy-audio/building-a-do-it-yourself-loudspeaker-design
    https://www.popularmechanics.com/technology/audio/how-to/a3485/build-your-own-speakers/
    https://www.instructables.com/id/How-to-Build-Custom-Speakers/
    http://techtalk.parts-express.com/forum/tech-talk-forum/38661-the-speaker-building-bible
    https://www.amazon.com/Loudspeaker-Design-Cookbook-Vance-Dickason/dp/1882580338/ref=pd_lpo_sbs_14_t_1?_encoding=UTF8&psc=1&refRID=YASC3M2YHPZ1PFQMB7ZY
    https://www.amazon.com/Speaker-Building-201-Ray-Alden/dp/1882580451
    http://projectgallery.parts-express.com/
    https://www.diyaudioandvideo.com/Guide/BuildSpeaker/
    http://speakerdesignworks.com/index_page_2.html
    https://meniscusaudio.com/product-category/speaker-kits/
    http://www.zaphaudio.com/
    https://www.madisoundspeakerstore.com/welcome.php
    https://www.css-audio.com/
    http://www.troelsgravesen.dk/Diy_Loudspeaker_Projects.htm
    https://www.youtube.com/channel/UCOuow_HIYmeaIqi42zVs3qg
    https://www.diyaudio.com/forums/loudspeakers/
    http://www.htguide.com/forum/forumdisplay.php?6-Mission-Possible-DIY
    https://www.hometheatershack.com/forums/diy-speakers/
  • WLDock
    WLDock Posts: 3,073
    jghglofer wrote: »
    @WLDock I got them free
    Nothing like free. Maybe you can find some cheap driver from the speaker buyout section at Parts Express that might work with those crossover points. Then, design a cabinet and build and fine tune. Might make for a fun garage, basement, etc speaker project.
  • sgmsmg
    sgmsmg Posts: 556
    @jghglofer
    I know it has been a couple of years but by any chance do you still have the 707 crossovers and would you be willing to sell them?
    Pre: Bryston BR20
    Amp: Buckeye NCx500
    Speakers: Polk L200
    Source: Oppo UDP-205, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
    Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
    Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
    Display: Sony XBR65Z9F
    Pre: Anthem AVM90
    Amps: Buckeye NC502
    Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
    Subwoofers: SVS SB16 x 4
    Source: Oppo UDP-205, Apple TV, Amazon Fire
    Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
    Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
    Display: Sony XBR85Z9G
