Can the Volume be louder on the Mini sound bar.
My question is, can the volume be made any louder than what I am getting by using the remote control volumes ( center speaker + master volume ) buttons. I was hoping that it could produce a louder output: Help !
Maybe double check that it's hooked up properly first. Then give us more details.HT SYSTEM-
lsi 9's -
How do you have it connected, HDMI, optical, analog? Check that your source volume is maxed.
I have it hooked up with the HDMI Cable to the ( ARC) TV Port. Where do I find source Volume ? I have noticed that by streaming movies , current day moves( VRs) 20 year old movies do come in louder. Is this normal ?
Can't control source volume, and the FCC puts caps on maximum volume. To counteract that, commercials and some movies are compressed and then normalized so that the average output is very close to the cap.
