How to Identify my Model of Speakers
Hello!
I have 2 Polk Audio speakers, which I no longer have the manual for. I am trying to identify their model #. I have had these speakers for years. On the back it says: polkaudio Monitor Series 2, M4.6 9028501, Designed and Manufactured in the U.S.A. by Polk Audio, Inc. Baltimore, MD.
I removed one grill cover and set the speakers side-by-side. Attached is my photo. I hope this helps. I have no idea how to set up these speakers with my audio equipment. I'm a newbie with this.
Thanks for all your help!
4mysound
  • FestYboy
    FestYboy Posts: 3,861
    The 4.6 was only available in the series 2 generation, and the step between the monitor 4.5 and the 5jr+.
  • verb
    verb Posts: 10,176
    Wow! In 5 minutes, answer given!
    And welcome to CP @4mysound :smile:
  • skrol
    skrol Posts: 3,460
    Here are the specs:
    Monitor 4.6 Series 2
    1990 $280
    Midrange 1 - 6-1/2" Diameter (16.51cm)
    Tweeter 1 - 1" Diameter (2.54cm)
    Polk SL2500 dome tweeter
    Overall Frequency Response 30Hz - 25kHz
    Lower -3dB Limit 48Hz
    Upper -3dB Limit 23kHz
    Recommended Amplifier Power 20-100 w/channel
    Efficiency 90 dB
    Impedance 8 ohms
    Dimensions Cabinet Size 17" H x 8-1/2" W x 10" D
    (43.18cm H x 21.59cm W x 25.40cm D)
    Shipping/Other Total Shipping Weight 34.00 lbs. (15.42kgs)
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • 4mysound
    4mysound Posts: 2
    Thanks for your help!
    pitdogg2 Posts: 27,235
    Boom that's what we do. Nicely done fellas.
  • skrol
    skrol Posts: 3,460
    Brotherhood (sisterhood too)!
    Stan
    Main 2ch:
    HT:
    Other stuff:
