Sonus Faber Venere S
xsmi
xsmi Posts: 1,801
Ok, so the dealer not too far from me has between 5 and 6 pairs of these brand new in box hat they are clearing out at $4K a pair because these have been replaced by a new set. According to them and SF, these are the last ones built in Italy. I have not heard these, yet, but was wondering what you guys think in this price range? I know it’s ultimately up to me, just fishing for thoughts. BTW, this would be all music, no movies.
2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
    F1nut Posts: 51,710
    Took a quick look....it appears $4k is what they were selling for.
    VR3 Posts: 29,402
    Quick Google search shows quite a few prices in the mid 3s new... Probably less than 2k used
    txcoastal1 Posts: 13,505
    They are closeouts then offer $3k, dealer has room. Wouldn't pay over 3400...just my opine
  • Upstatemax
    Upstatemax Posts: 2,735
    I think original retail was between $5k and $5,500 depending on finish.
    For the money, I love them. It is a BIG speaker, make sure you have room.
    They do better with solid surface under them. Much better bass response.
  • xsmi
    xsmi Posts: 1,801
    $4K for the Walnut. VR3, where did you see mid $3's? I'm gonna search though.
    Thanks.
  • xsmi
    xsmi Posts: 1,801
    Upstatemax, I have a room 16x24. Should that be large enough? I have some freedom on the short side to move the wall back about 4'.
    xsmi wrote: »
    How far would your listening position be? If you don't have the bass response that you like, can you add a sub later?
    xsmi wrote: »
  • xsmi
    xsmi Posts: 1,801
    txcoastal1 wrote: »
    xsmi wrote: »
    Haven't gotten that far yet. It will be MY dedicated listening room so I can sit as close or far back as needed. I prefer not to have a sub with 2ch. Whatever bass, I'm missing, I'm missing. It's a tradeoff that I'm willing to make.
  • xsmi
    xsmi Posts: 1,801
    DSkip wrote: »
    xsmi wrote: »
    That's a large room but the Venere S isn't a small speaker. It should do well but would benefit from a nice subwoofer later on. Is your room a lively one? If so, the Venere S might not be the right speaker without addressing the room/synergy. They don't have the traditional Sonus Faber sound, which is why I like them.
    I'm supposed to go hear them later this week, but this sentence gives me pause. The SF sound is actually what I was hoping for.
  • Upstatemax
    xsmi wrote: »
    I think it will be big enough.
    My room is similar in size, but my ceiling goes up to a 16’ tall peak with several large openings to other rooms, so it’s hard for me to say if you have a normal ceiling height and few openings.
    I personally find their bass to be plenty all on their own, but I’m also not a bass head. As others have said though, easy enough to supplement with subs should you want more bass.
    As for the sound, I would say slightly more forward than the typical SF sound, tighter more analytical bass. I would not call them a forward speaker though.
  • xsmi
    xsmi Posts: 1,801
    Let me go hear the Venere's.
  • WLDock
    WLDock Posts: 3,073
    Those tilted lyre shaped cabinets in walnut look fabulous!
    In the $3K-$5K range you HAVE to listen to everything that you can. So many choices!
  • Upstatemax
    WLDock wrote: »
    Agree!
    I LOVE my walnut Venere S speakers.
    Listen to everything you can, so many options in the price range and they will all offer something different.
  • WLDock
    WLDock Posts: 3,073
    edited June 2019
    Upstatemax wrote: »
    WLDock wrote: »
    Agree!
    My listen to them was so brief but I I'm sure I could even live with the 2.0 or 3.0. They would be a visual highlight in my space for sure.
    Just beautiful!
  • oldrocker
    oldrocker Posts: 2,590
    I really like the look of those.
  • xsmi
    xsmi Posts: 1,801
    edited June 2019
    So, I uh, I uh...bought Big Dawg's SRS's. I guess I WON'T be buying any Sonus Fabers.
  • xsmi
    xsmi Posts: 1,801
    Yeah, I know.
