14344464849172
  • ZLTFUL
    ZLTFUL Posts: 5,587
    Bought some more powerful subs for my folded horns but turns out that the surrounds on pretty much every 8" sub capable of more than 400w power handling is WAY too big to go into the sub cavity of the horn. So I put the Daytons back in and played around with the DSP on the amp a bit more.
    Have a bit of a bump at 40, 60, 80 and 100hz for the subs (3, 2, 2, 1db resepctively) with HP set at 20hz and LP set at 120hz. The slopes are Butterworth 48db/octave on the 20hz side so it drops off a cliff and then a Butterworth 6db/octave on the 120hz side so the slope is nice and gradual.
    Seems to be giving me most of what is missing on the low end due to the room modes/nulls. But it is still not as good as just the speakers themselves in that damned hotel room at LSAF. The problems of dealing with a very compromised space.
    VR3 Posts: 27,117
    Tri Vista dac is about burned in at this point I would guess. Very happy with the results
    https://youtu.be/TBMOgRv0oBU
  • agfrost
    agfrost Posts: 2,401
    jdjohn wrote: »
    Got a used Micro Seiki MA-505 tonearm :) Yeah, it's missing a couple of bits, but those have been procured and are in transit. Bearings are in perfect working order. Ok, it's a little rough around the edges, but I got a good deal on it, and it should clean up enough to suit me. I'm much more about function over form when it comes to cosmetic issues, but that's just me.
    Very nice. I've got a variant (not the 'standalone' unit you have) on my MS DQ-50. Been a fine performer for me.
    Jay
  • stangman67
    stangman67 Posts: 2,007
    Cranked it up for the first time in a week or so. Still smiling from ear to ear :)
    treitz3 Posts: 16,961
    To answer my own question ~
    Not a damned thing but listen.
  • verb
    verb Posts: 10,176
    jdjohn wrote: »
    As a Mechanical Engineer, that thing is one of exquisite beauty! Oh, the engineering drawings, tolerance stack ups, machining and material specifications, testing and validation, I could go on. That would have been a fun project to work on! :smile:
  • displayname
    displayname Posts: 1,069
    Received some Wireworld Mini Eclipse 8 speaker cables today. Preparing my self for a little shoot out with my current with my current Zu Libtec speaker cables.
    Analog: MoFi MasterTracker > MoFi UltraDeck > Sutherland 20/20
    MastersounD Dueventi > Rosso Fiorentino Certaldo or Arcam rHead > Hifiman HE4XX
    Discogs
    pitdogg2 Posts: 22,728
    edited May 2019
    verb wrote: »
    Picked this up today from CL. Amish built, 3/4" solid oak. For the office! :smile:
    just 6 more of those and it might be enough to cover my CD, SACD collection :D
    I really should put some effort into looking into a boltz system for them.
  • DaveHo
    DaveHo Posts: 3,393
    Rip to NAS and boxem
    nooshinjohn Posts: 24,404
    DaveHo wrote: »
    Or offer them up as Karma
    The Gear... Carver "Statement" Mono-blocks, Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 380d DSDIn retirement...TriangleArt Reference SE with Walker Precision Motor Drive, Yamaha CD-S2100 SACD Player.“Every record has been destroyed or falsified, every book has been rewritten, every picture has been repainted, every statue and street building has been renamed, every date has been altered…History has stopped. Nothing exists except the endless present in which the party is always right” — George Orwell“If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it.”
  • verb
    verb Posts: 10,176
    Yep. I have most of my CD's in the basement, but the one's in the office were just stacking up! :smile:
  • joecoulson
    joecoulson Posts: 4,944
    DaveHo wrote: »
    You first
    joecoulson wrote: »
    DaveHo wrote: »
    You first
    One step ahead of you...
    DaveHo wrote: »
    Nope I'm a physical media guy.
    Tony M Posts: 10,876
    That's what I'm talkin about! :D Look at all the colors.
    I like! B)
    Organized too.
    I can't wait to get back to my "pyramid tower"of relaxation Cds.
    Clipdat Posts: 12,054
    Nice CD collection there, Bud!
  • verb
    verb Posts: 10,176
    Thorton wrote: »
    Added a marine amp to the pontoon. It sounds so much better. Great upgrade.
    What lake do you live on/near? Just asking, cause I'm coming over! :smile:
    I used to live on Silver Lake! :smile:
  • DaveHo
    DaveHo Posts: 3,393
    I must say, at one time or another, I've owned 7s, 9s, and now 15s. The 9s, which I had on a pair of Sanus Ulimate stands prior to swapping in the 15s, were a better speaker. Listening 2 channel, no sub, the 15s have bloated flabby bass and lean way too much toward the bottom end. Anybody got a pair of Db840s they want to sell? :)
    Hi, Dave. The 9's were my favorite in that lineup as well.
  • BlueBirdMusic
    BlueBirdMusic Posts: 1,902
    VR3 wrote: »
    Can you post a summary of what was done to it? What improved?
    Thanks,
    Harry
    Harry / Marietta GAsf0ql39qaakz.png9iydbldgbzbo.png
    VR3 Posts: 27,117
    Quite a bit..
    Wbt next Gen analog out and digital in and upgraded wiring
    Mundorf and audio note power supply caps
    Sparks dual board discrete op amps
    Discrete voltage regulators
    Changed most signal path resistors
    Changed most signal path caps with audio note
    Changed some diodes
    Tube coupling caps, clarity cap mr
    Output coupling caps, clarity csa
    Not to be cliche, but this was a fairly substantial improvement. Micro detailing, staging, bass accuracy and impact.... I'm a frugal person and the money spent was worth it for sure. I run a passive line controller so my end result is pretty much up to my source.
    SCompRacer Posts: 8,079
    edited May 2019
    It's DeoxIT® Day.....so many cables and connections!
    Trey will either bring his down here, or I will bring mine up there sometime soon to compare the differences between a stock Tri-Vista and his modified. He is trying to talk me into getting mine done as well.
  • lightman1
    lightman1 Posts: 10,738
    Bought these bricks...^^^
  • verb
    verb Posts: 10,176
    edited May 2019
    Rocking my Polk Camden Square in the garage while re-finishing an oak desk for the Mrs! :smile:
    You've got a lot of various odd tools, dowel rod and glue on that top.
    Looks like a few projects going on at the same time. ;)
