Crack #4
ALL212
in Headphones
No clever name for this one yet. It's pretty much a standard Crack with upgraded components but everything is moved around for the bigger plate.
This won't be as upgraded as the BAC version - just no room to get that crazy.
Output caps will be paired so one set on top of the plate and the other set below. Last power supply cap is 450uf so that I can keep the output caps smaller - these will measure out to 79uf per channel instead of 100uf. With the 300 ohm cans this should work just fine.
Wiring is about 75% done.
Aaron
Enabler Extraordinaire
Like crack you just keep coming back for more of those kits eh"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
It ain't called CRACK for nuttin'! It's just a fun build. Simple enough that moving things around is a challenge but still doable.
The box it's on was for another crack build but math got in the way and it didn't fit the standard crack plate. It's been laying around for a couple of years and it was time to put it to use.Aaron
Enabler Extraordinaire -
That's one of the best excuses I've ever heard for acquiring an audio project. Second only to, "I had an unused power outlet."I disabled signatures.
Perfect! I’ve got some scrap 2 x 4s in the shed...What can I build?
ooooo...I've got both open outlets AND 2x4's!!!Aaron
Sweet jebus, # 4.... I kinda expected exotic wood cap supports.
Kinda like.... the caps in the cradle....
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
And the caps isolated from the cradle with Sorbothane.I disabled signatures.
No cradle but there is a plan in place to keep the caps off of the plate using some cushion material.
I'll take a shortcut and just spike the caps!Aaron
If you're not a hack, you'll do this with the unit powered up. And wet hands.No cradle but there is a plan in place to keep the caps off of the plate using some cushion material.
I disabled signatures. -
Can I wear my steel grounded boots and necklace?Aaron
Post edited by SCompRacer onSalk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Aaron
How's it sound?
Like schitt"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Needs some breakin time but it’s nice...very nice!
Aaron
Love your crack!
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Awwww... thanks!
And the headphone amp, what about it?Aaron
Very nice! What cans are you powering with this?
I started with the Senn HD650's but am using the ZMF Auteur now. I do think the speedball will get installed sooner than later. Mids/upper registers are good but the lower mids/bass is loose/wobbly/not tight.Aaron
Check out this Bottlehead on eBay (no affil), it's very nice! https://www.ebay.com/itm/New-Bottlehead-Crack-OTL-1-1-Headphone-Amplifier-w-Speedball-Angled-Wiring-6080/323754273089
That is an incredibly clean build!
We done. Speedball installed and the BH badge is attached.
Aaron
That's awesome! Very nice setup! -
