Crack #4
ALL212
ALL212 Posts: 1,653
No clever name for this one yet. It's pretty much a standard Crack with upgraded components but everything is moved around for the bigger plate.
This won't be as upgraded as the BAC version - just no room to get that crazy.
Output caps will be paired so one set on top of the plate and the other set below. Last power supply cap is 450uf so that I can keep the output caps smaller - these will measure out to 79uf per channel instead of 100uf. With the 300 ohm cans this should work just fine.
Wiring is about 75% done.
Aaron
Enabler Extraordinaire
    EndersShadow Posts: 17,701
    Like crack you just keep coming back for more of those kits eh
  • ALL212
    ALL212 Posts: 1,653
    edited May 2019
    It ain't called CRACK for nuttin'! It's just a fun build. Simple enough that moving things around is a challenge but still doable.
    The box it's on was for another crack build but math got in the way and it didn't fit the standard crack plate. It's been laying around for a couple of years and it was time to put it to use.
    Aaron
    msg Posts: 10,452
    That's one of the best excuses I've ever heard for acquiring an audio project. Second only to, "I had an unused power outlet."
  • maxward
    maxward Posts: 1,683
    Perfect! I’ve got some scrap 2 x 4s in the shed...What can I build?
  • ALL212
    ALL212 Posts: 1,653
    ooooo...I've got both open outlets AND 2x4's!!!
    Aaron
    SCompRacer Posts: 9,090
    edited May 2019
    Sweet jebus, # 4.... I kinda expected exotic wood cap supports.
    Kinda like.... the caps in the cradle.... :D
    msg Posts: 10,452
    And the cradle should be spiked.
    msg Posts: 10,452
    And the caps isolated from the cradle with Sorbothane.
  • ALL212
    ALL212 Posts: 1,653
    msg wrote: »
    No cradle but there is a plan in place to keep the caps off of the plate using some cushion material.
    I'll take a shortcut and just spike the caps!
    Aaron
    msg Posts: 10,452
    ALL212 wrote: »
    If you're not a hack, you'll do this with the unit powered up. And wet hands.
    pitdogg2 Posts: 26,988
    msg wrote: »
    And the cradle WILL ROCK !!!.
    Fixed it for you Scott
  • ALL212
    ALL212 Posts: 1,653
    edited May 2019
    msg wrote: »
    ALL212 wrote: »
    Can I wear my steel grounded boots and necklace?
    Aaron
    msg Posts: 10,452
    MY EYES! MY EYES! GAAAAAH!!!
    edited May 2019
    Post edited by SCompRacer on
  • ALL212
    ALL212 Posts: 1,653
    edited May 2019
    Seems “extreme”. Maybe next one.
    It works!!
    @msg tinfoil panties...
    Aaron
  • ALL212
    ALL212 Posts: 1,653
    Guts
    Aaron
  • zingo
    zingo Posts: 11,258
    Clipdat Posts: 13,089
    How's it sound?
    Like schitt
  • ALL212
    ALL212 Posts: 1,653
    Needs some breakin time but it’s nice...very nice!
    Aaron
  • verb
    verb Posts: 10,176
    Love your crack! :smile::smile:
  • ALL212
    ALL212 Posts: 1,653
    Awwww... thanks!
    And the headphone amp, what about it?
    Aaron
  • verb
    verb Posts: 10,176
    ALL212 wrote: »
    Awwww... thanks!
    Uh, that too I guess! :smile:
  • Dawgfish
    Dawgfish Posts: 2,554
    Very nice! What cans are you powering with this?
  • ALL212
    ALL212 Posts: 1,653
    I started with the Senn HD650's but am using the ZMF Auteur now. I do think the speedball will get installed sooner than later. Mids/upper registers are good but the lower mids/bass is loose/wobbly/not tight.
    Aaron
  • ALL212
    ALL212 Posts: 1,653
    That is an incredibly clean build!
    We done. Speedball installed and the BH badge is attached.
    Aaron
  • Dawgfish
    ALL212 wrote: »
    That's awesome! Very nice setup!
    ALL212 wrote: »
    So nice somebody snatched it up already!
