polk 4's with the peerless...same crossover as the 7's with the peerless?
i have some polk 4s and would like to make a bigger cabinet for them along with passive radiator. can i just take out the guts of the 4's and make a bigger speaker and give it some more bass?
M7's 1982 Peerless tweeters
M5's X2 (1981 Peerless tweeters, 1988 with upgraded tweeters)
M4's X2 both with Peerless tweeters
M5Jr with SL1500 (in the garage, they sound great)
M4.6 series2 X2 with upgraded tweeters
SDA 2 with upgraded tweeters
  • anton.chigurh
    anton.chigurh Posts: 239
    Buy some 5, 7, or 10s if you like your 4s but want more bass.
    F1nut Posts: 51,880
    wispolkboy wrote: »
    Get a good sealed subwoofer.
  • wispolkboy
    wispolkboy Posts: 150
    thanks for your replies. I have 10's, 5's, 5jr's, 4's, sda's 2. I guess forget about the "more bass" in my question. are the crossovers the same as the 7's? I'm a woodworker and would like to build a nice cabinet for the extra 4's I have. I want more of a floor speaker and not a bookshelf.
  • Faustin
    Faustin Posts: 1,151
    The early monitor 4's with the Peerless tweeters I had several years ago actually had the same c/o as my Monitor 10's with Peerless. Pull a c/o out and take a look at it.
  • wispolkboy
    Faustin wrote: »
    thanks!
