Added some MIT EXPs2 cables. My problem is whenever I do one change or upgrade I also do something else so no idea if the changes I hear are due to the cables or speaker placement. However the length of the cables allowed me to move my rack from between the speakers to outside to the right of them.Just a dude doing dude-ly things
"Audiophiles are the male equivalent of cat ladies." - Audiokarma Member -
I swapped my old interconnects for the Groneberg I just received from @ALL212. So, apparently nothing much. The old ones (DAC to preamp) we’re Straight Wire Symphony II and too long for the purpose. I was pleasantly surprised with the new ones and told Aaron as much. The Odyssey website showed that they should be connected one way, but Klaus emailed me with the opposite recommendation. So I swapped ends thinking that could hardly make a difference, but i think it did. When I played Pop Pop by famous vocalist/mumbler Rickie Lee Jones, I was able to understand a bit more of the words. This is a nice, mostly acoustic, album that was used by the guy to demonstrate the Joule Electra to me when I bought it. At the time, I had not heard much of it. Thank you, Aaron.
Hey Aaron was reading through some old threads. IIRC, did you ever modify/upgrade your Joule?Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
So I had to hook up these little babies in the upstairs rig. Nelson Pass Amp Camp monoblocks! Eventually they’ll make it into my office rig. Test driving em now!
WOW! Nice! you'll have to start spending more time in the bedroom now!Gustard X26 Pro DAC
^you typically stay for that behavior
That dresser looks like something from a 1970’s waterbed room set...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
Got a used Micro Seiki MA-505 tonearm Yeah, it's missing a couple of bits, but those have been procured and are in transit. Bearings are in perfect working order. Ok, it's a little rough around the edges, but I got a good deal on it, and it should clean up enough to suit me. I'm much more about function over form when it comes to cosmetic issues, but that's just me.
So today is day 2 with these little guys, and having fun! They sound great! More critical listening is store for sure, but one thing I noticed almost immediately was the lower end was better, Seemed to be extended and a bit tighter compared to the Antique Sound Labs monoblocks.
Shpongle putting em through the test!
Another surprise for me was that these little heaters never really got that hot! Warm yes, concentrated toward the center of the heatsink, but not bad to the touch. Even after about 90 minutes of playtime. So, IMO no need for special measures to manage the heat.
Having fun for sure! Loving these little guys!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
looks purposeful.
Spend some time with a good detailer and the proper tools and it should shine up like new. Good score.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Thanks! Detailing is my specialty I like Peek cream or paste for polishing. It has diamond dust mixed into it. Greased Lightning is my go-to de-grimer for anodized aluminum oxidation as a first step. Unfortunately, I can't fix pitting Also need to clean and re-lube the VTA section.
It is all a little sticky, and not working as intended."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
You can take the pitted parts and have them reworked if you want to go that deep taking it apart.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
I replaced my Rotel transport with my Marantz. The silver face stuck out too much in the sea of black. I ended with cleaner looks and cleaner sound.
I mean, a broad point black Sharpie could've taken care of that problem.
Tidal HIFI rocks .....
Why buy CD’s ?
BkStarted a subscription to Tidal...finally. I am wondering WTH took me so long now.
Parasound A21 , Yamaha wxc-50 , Polk SDA 1c’s ( my first love .. ) , Kimber Kable 4TC, Sony 42” - BEDROOM
B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Yamaha wxc-50 , Boston Acoustic voyager 7’s - POOL
PS Audio Stellar S300 , Eversolo DMP-A8 , Yamaha wxc-50 , Kimber Kable 4vs , Salk Supercharged Song towers ( difficult choice between these and my family if I had to choose ... 😩 ) , Sony XBR-A8F 65” OLED - DEN , MAIN RIG
Cambridge Audio 851n - sitting in the closet , for now
Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sharp 65” TV - PATIO
DAYENS AMPINO ( thanks Verb ! ) , KEiiD streamer ( this was only 60 bucks ?? ) , Polk atrium 8SDi’s - KID’s BEDROOM -
Added a marine amp to the pontoon. It sounds so much better. Great upgrade._____________________________________________________________________________________________
DAC: Bricasti M1SE
Pre/Pro: Marantz AV8805
Subs: 2 - Rythmik F25's
Room Treatments: GIK Acoustics -
Not to sound stupid, but what is a ‘marine amp to the pontoon’? It sounds aquatic.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Marine amplifiers are similar to car audio amplifiers but the boards are dipped in an epoxy to seal the components from moisture intrusion.
A pontoon is a type of boat usually a large platform mounted on 2 or more pontoons (of floats) allowing for a large platform for aquatic parties, fishing, "camping" etc."Some people find it easier to be conceited rather than correct."
"Unwad those panties and have a good time man. We're all here to help each other, no matter how it might appear." DSkip -
Okay. Thanks. We went from land stereos to boats.
Thanks ZLTFUL
DAC: Bricasti M1SE
JL Audio....nice job @Thorton.
It's a drinking barge.....
I’m replacing all cables with MIT T2 (period correct), one at a time!
Playing with the Acurus A80 after swapping out the power switch last week. Liking it so far!
Following @verbs lead, I built an amp stand for my Stratos Extreme. Excuse the crappy cell phone pics.
Looking good Jeff!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
I just bought this...
https://www.audiogon.com/listings/lis9e6ba-sweetvinyl-sugarcube-sc-2-black-new-in-box-turntables?show_listing=trueThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
wtg! very nice ..I have to use amp stand myself....nice!!!
oops this was for what Indyhawg was doin! So ROCK on my Man!!!2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
nooshinjohn wrote: »
Congrats on that acquisition. I caught a demo of the Sugarcube last year at AXPONA. It was the most impressive thing we saw all day. It has been on my wishlist for a.while now.
