Does anybody sell vinyl sourced exclusively from analog tapes?
muncybob
My sister made a comment that records sound better than cd's....that got me going. I know that just because something is digital doesn't make it inferior to analog but, if I'm buying a record I want it to be totally analog...or I'll just buy the digital format.
Yep, my name really is Bob.
Good question, Bob. Watching.
Ideally, I'd want to throw in, with proper oversight of the pressing process for high quality, clean, flat pressings.I disabled signatures. -
Any vinyl pressed before the late 80s ๐Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Well, except, e.g., Ry Cooder's Bop Till You Drop.
1979
Image is a borrowed one, but my (purchased-new, way back when) copy still has the shrinkwrap & the sticker on it
It is a pretty good record, sounds pretty good, too, albeit a little dry.
In terms of the original question, I suspect (?!?!?) that most of the modern re-releases on vinyl of recordings taken "from the original analog master" (or whatever) pass through the digital domain somewhere along the line for convenience or practicality
