Lsim 705 vs rti12's
How much difference in sound between these two speakers??
Best Answers
  • Emlyn
    Emlyn Posts: 4,719
    Answer ✓
    Let the new speakers play for a couple days on low volume before making an assessment. The LSiM series sounds more natural. You may find the RTi12s put out more bass, simply because of the larger cabinet volume, but have harsher treble. Some prefer that type of sound for home theater. I had a pair of RTi12s at one time. They were fun speakers with a lot of amp power put into them, but not nearly as refined as the LSiM line.
  • cfrizz
    cfrizz Posts: 13,415
    Answer ✓
    Congrats on your purchase. Only your own ears will tell you if you like the difference in sound. As pointed out, the RTIs are built for HT, the 705s are built for music first.
    Fortunately you have plenty of power so they will operate to their full potential from the get go.
    The sound will be very different from the 12s so give yourself time to get used to the sound. Put on some of your favorite music that you know well and listen for the differences. I think you will be very pleased by the difference. Enjoy.
    Be sure to post back on what you think once both you and the speakers have had a chance to settle in. :)
  • rooftop59
    rooftop59 Posts: 8,121
    Answer ✓
    They are probably the two most different sounding speakers in the entire Polk lineup. All others have a warm, slightly laid back sound sig except the RTi, which are forward and bright. I personally hate bright speakers (though forward can be fun when done right), but as said it’s gonna up to you and what your ears prefer.
    Give the new LSiMs at least 2 weeks of dedicated listening before listening to the 12s again. That way they will break in and your ears will adjust and you can make a fair judgment.
    Game Room 5.1.4:
    Bedroom 2.1
  • transchris
    transchris Posts: 28
    Answer ✓
    Thanks for all the info!! Now,just hope they don't come damaged in shipping!!!
  • erniejade
    erniejade Posts: 6,321
    Answer ✓
    Should be a good match for them.
  • erniejade
    Answer ✓
    Not everyone will agree with me but when I had the 705's, I thought it was a bit thick sounding but, that could have been the components I had at the time. I thought a brighter sounding amp would make them sing better. I was running a McIntosh amp and Tube Joule preamp at the time.
  • rooftop59
    Answer ✓
    erniejade wrote: »
    I didn't love my 703s until I got a rotel 200 wpc amp. Rotel is not a particularly warm amp, so I think that the combination of a pretty neutral SS amp and lots of current really helped open them up. But the bass continued to be a little fat and unwieldy to my ears...
    Game Room 5.1.4:
    Bedroom 2.1
  • dromunds
    dromunds Posts: 10,129
    Answer ✓
    You'll need to let them break-in for quite some time before they start sounding good if they are anything like my 703's. Didn't really like them until I had more than 50 hours maybe 100 then they really started sounded good. Before that it was up and down sound quality. Some guys say they didn't require a break-in but mine sure did. Now I consider them the best bang for buck speaker around
  • erniejade
    Answer ✓
    The 12's were awesome for HT but straight music, they were bright for my ears. The 705 is the better choice. Also good to know you could hear the difference between the B&k and emo amps.
    How are the airmotv 2? Anytime i heard them it was in a ht type environment not for 2,channel misic.
Answers
  • codycatalist
    codycatalist Posts: 2,662
    A lot.
  • transchris
    Would that be in a good way?? I just purchased the 705's will be here Wednesday... I'm also running 250 watt amp and preamp...all Emotiva..
  • transchris
    I just received my 705's.And wow!!! Right out of the box they sound so nice..David Sanborn and Rush... sounds like they're in my living room...I'll update as Igo through the break in period!!!
  • transchris
    Update:I swapped out the Emotiva amp with a B&K reference 5250,both are awesome amps, however I just wanted to try it..the bk is more light sounding.Very nice Balance.I tryed the 705's with the rti series in 5.2 mode and it sounds horrendous.So my RTI series are up for sale.
    My other system is all Emotiva including the speaker's, Airmotiv T2's and c2.the surrounds are rti8's.The sound is very well blended..Overall,I am extremely pleased with the 705's..
  • transchris
    erniejade wrote: »
    The 12's are great,the 705's are just better all around..very happy with them..The T2's are simply awesome!!! First,they are 4ohm , I'm running an XPA2 gen3,so that's close to 500 watts.My preamp is the XMC1,and two Velodyne subs.The sound is simply amazing!!!For ht I have the xpa5gen2.Movies are so good in this setup.For my other setup,the b&k amp is a power House also.Very musical!! I'm running a marantz preamp with 2 psw505 subs..I'll eventually get another XPA2 for the ,705's.I can tell you that the RTI series sounds terrible with the lsim series.
  • cfrizz
    Pics please.
