R series grille on or off?
shaddai
shaddai Posts: 32
edited January 2005 in Speakers
Hi all,
In general, is it better for sound reproduction to keep the grilles off? I normally keep them on to protect the delicate tweeters that so often have been maimed in stores like CC, BB, etc. I would imagine that the more expensive the speaker, the more likely the grilles are better designed for transparency. I own all R series speakers except for the center channel, which is CS1 of the Monitor line. I know it will look a little goofy with the titanium face of the center channel and the rest being black but I'm not too concerned about that right now. I would like the opinion of other R series owners out there. Thanks!
Home System:
Receiver - Onkyo TX-SR601
Mains - Polk Audio R50
Center - Polk Audio CS1
Rears - Polk Audio R20
Subwoofer - Aiwa TS-W60
TV - 32" CRT Sony KV-32HS500
DVD player - using HTPC
Post edited by shaddai on
  • steveinaz
    steveinaz Posts: 19,545
    edited January 2005
    It's a personal preference call. Try it both ways, see what you like best. I leave mine off unless guests are coming that have children, then I pop them on....
  • Mjr7531
    Mjr7531 Posts: 856
    edited January 2005
    I personally like the look and sound of the R series without a grille, but because of our new kitten and placement of my R20s, I prefer to keep them on, just in case.
  • TheReaper
    TheReaper Posts: 636
    edited January 2005
    I keep mine on, they are in a high traffic area (where people walk past).
    Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
  • okiepolkie
    okiepolkie Posts: 2,258
    edited January 2005
    shaddai
    I like my 7's naked. I usually like the grilles off my speakers to minimize any diffraction they might cause (and they look much sexier).
    If you are talking about the R30 or R50, then I think they look better off(I dislike those grilles very much). The R15 and R20 look fine to me with the grilles on.
    Actually, your hypothesis that more expensive speakers have better grills may not always be the case. Many(not all) manufacturers will even recommend leaving the grilles off because they have focused much of their time and resources in the speaker itself, and put a grille on as an afterthought.
    In the end it is a personal preference.
    Tschüss
    Zach
  • TheReaper
    edited January 2005
    Originally posted by okiepolkie
    ... If you are talking about the R30 or R50, then I think they look better off(I dislike those grilles very much) ...
    I have the original R50s with the black lacquered wood veneer. Their elegance is their simplicity of design, a vertical box with an arch on the bottom.
  • shaddai
    shaddai Posts: 32
    edited January 2005
    Thanks for all the replies, guys!
    I don't have any kids or pets so I guess I'll leave them off unless I'm moving them around the house. The grilles on my vinyl R50's do detract from the overall appearance. I think I'll need to buy those computer dust sprayers for the occasional cleaning around the tweeter and woofers.
    Home System:
