Decware EL34 Single Ended Triode amplifier
doctorcilantro
Hey folks,
I've got two pieces left of my last stereo system. This beauty was the centerpiece of my SET system using the Zu Union Cubes (real bang for the buck!).
Here is the quick run down:
First owner
Single stereo input
No gain control
110 voltage
Switch for hi/low impedance
Fully upgraded equivalent to current model: VCAPS, UFO transformers, bias mod
Black Limba exotic base
It's baddass
I have some nice tubes I will include: POPE 7DJ8/PCC88 (Upscale Audio), EL34 PSVANE smoked Treasure II, new production Tung Sol EL34(brand new), Gold pins Gold Grid 6N1P-VI (6DJ8 ECC88 6922) pair, another pair of Russian input tubes recommended by Steve (need to check which I have), stock 5U4 rectifier.
This amp uses a pair of 6N1Ps driving a pair of EL34 output tubes. You can alternately use 6N2P, 6DJ8, 7DJ8 or 6922 in place of the 6N1P.
EL34 output tubes may be substituted with the following: KT77, 6550 KT66 KT88 6L6s, 7027 and with a socket adapter, 807.
Because this amp has the Hazen Grid Mod that activates only when EL34s are used, we ship the amp with top grade EL34/6CA7s that have been fully tested IN the amplifier. All tubes come with a 90 day warranty.
Asking $1775 net total shipped.
First owner
Single stereo input
No gain control
110 voltage
It's baddass
For Sale 2019:
Tortuga Audio LDR passive preamp
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
That is a thing of beauty!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Bump dropped to 1600 shippedFor Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center -
Dropped to 1500 net total shippedFor Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
bumpFor Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
bumpFor Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
bumpFor Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
still available 1400 net total shipped.For Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
