Looking at doing a second tube amp build...
Certainly does, and in this case it cuts both ways.... blind test between McIntosh MC601’s on B&W 802d’s at Magnolia... my amps destroyed the Mac’s by all accounts. My amps bested Bob’s 305’s at his old dealer here in Beverly Hills....“Those that don’t know, don’t know that they don’t know.”
Ring a bell?
You simply cannot claim that mine are missing something without hearing them yourself, and next time you get to L.A. you ar welcome to play with them to your hearts content. I will even send them to you to try out yourself if you pay the freight.
Never take these discussions to PM. Otherwise nobody learns anything, either about technology, or about personality.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Your posts came across as calling my babies ugly, so to speak, and after spending so long building them, not something I care to hear. I respect what you are trying to say, and as I get closer to rolling forward, I will reach out to you. Right now they are still on the sketch pad.
What is your opinion of high mass turntables?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Its about resonant frequencies and how those frequencies get carried away from, or, transferred back in to the unit. Stone materials are notorious for being particularly bad about carrying those bad frequencies in.
FWIW... my granite is not directly coupled to the chassis. It sits on double sided foam tape and a silicone based adhesive, so there is some isolation between it and the aluminum chassis underneath.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Regardless of anything else they are beautiful amps.Political Correctness'.........defined
