MacBook info needed
vmaxer
vmaxer Posts: 5,116
Hey guys & gals,
My daughter will be starting college soon, (too soon for me). She is wanting to go with a Mac of some type, I have never used or had one, sooooo - some is needed.
I see MacBook, MacBook Air, and MacBook Pro. I guess they get better as you go up.
Any opinions that aren't overkill on what to get??
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
    msg Posts: 9,466
    I think Al can help you here. Apple wanted desperately to hire him as a subject matter expert after all the research he did not long ago :D
    @scubalab
    Try to get a sense for use, and that will help you narrow down a few choices.
    Things to consider, as with any notebook:
    • Screen - size, resolution, glossy/matte
    • Battery life
    • Weight
    • Performance (need to know which applications you'll be running and whether you want virtualization to be able to run Windows)
    • Storage
    Set some general guidelines or your head'll be spinning. One thing I learned with Al was that the newer machines aren't user upgradeable anymore, so however its specced when you buy it is what you're locked into. Of course, Apple may already have changed this :)
  • tonyp063
    tonyp063 Posts: 1,048
    And make sure you get the longest AppleCare warranty that you can.
    When, not if, but when something goes south she'll need it.
    I've watched *many* faculty & such here cheap out on that & it bit them hard.
    Most campuses have an Apple affiliation, or access to a certified repair place, but it's bloody costly out of warranty.
    And you & I both know that she'll have problems about the day before a paper is due.
  • vmaxer
    vmaxer Posts: 5,116
    msg wrote: »
    @scubalab
    • Battery life
    • Weight
    • Storage
    Screen - size, resolution, glossy/matte - She likes the small sizes, I am thinking 13"
    Battery life - all look good enough
    Weight - Lighter is good, but they all are acceptable.
    Performance (need to know which applications you'll be running and whether you want virtualization to be able to run Windows) - Not sure what virtualization is?? Of course all the Micro Soft Office applications, plus I'm not sure what else. Studying to be an RN
    Storage - can get an additional ext hard drive if needed.
    One thing I learned with Al was that the newer machines aren't user upgradeable anymore, so however its specced when you buy it is what you're locked into. I think this is still the case.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • rooftop59
    rooftop59 Posts: 7,981
    Honestly with normal studying and an RN track, a MacBook Air 11 or 13 should be fine. I would get at least 256gb hard drive and 8gb of ram. Yes, you can use an external hard drive but it gets to be a pain. She might be able to get by with 128 gb but definitely no less. Unless she is running really intensive programs like music or video editing software she should be fine with 8 gb of ram. As a college prof I used a MacBook Air 13 with 256 and 4 and it was fine, though I did wish I would have upgraded the ram. I used it for three years, no prob.
    Game Room 5.1.4:
    Bedroom 2.1
    msg Posts: 9,466
    Yeah, I second the 256GB / 8GB combo, minimum.
    I had a bunch written here about the Windows virtualization piece, but we can skip it. It's just a way to run Microsoft Windows on the same computer as macOS.
    Find out if she needs any specialized software for her study program that requires Windows, just to be sure.
  • sbb2112
    sbb2112 Posts: 134
    I have a mac book pro and I have changed a couple things. More ram was installed and a bigger hard drive. Apple is making those harder to do as time goes by. A 500gb drive is fairly reasonable and 4gb minimum ram. I run parallels ( a program that allows virtualization) so I can run both mac os programs and run Microsoft windows programs simultaneously. The ram has a big affect on how well this works. I use the mac os to do all internet activities and the windows side for accounting and for programs where there is no Mac equivalent. I personally like the matte screen for no glare and no fingerprint smudges.
    Main System
    Marantz AV8802A PrePro
    Marantz MM7025 Amp rear surrounds
    McIntosh MC7205 Amp center, ceiling and mid surrounds
    McIntosh MC300 Amp front mains
    Oppo 203 Bluray
    Polk SDA-SRS with VR3 monastery crossovers
    Polk FX1000 Mid surrounds
    Klipsch RP-440C Center channel
    Klipsch RP-15M Rear surrounds
    SVS prime elevation ceiling surrounds
    Rythmik F15HP sub
    Samsung 8500 curved screen 65" LED 4K
    Mac Mini Server
    Office System
    Musical Fidelity M6s dac/preamp
    Oppo 103D Bluray
    Polk SDA-SRS 2
    Parasound HCA-1500A
    Polk PSW 650 sub
    Microrendu
    Roku Ultra
    Mac Mini Server
  • markmarc
    markmarc Posts: 2,309
    I'm on my third MacBook over 15+ years, so here are my thoughts:
    Load up on RAM, programs will only get larger over the years.
    500gig HD is crucial.
    13" screen may seem unnecessary, but late night tired eyes will appreciate the additional screen real estate.
    AppleCare is an absolute must!
    Before spending $$ on MS Office, find out if the campus standard is MS or Google.
    Make sure to look at the Apple Refurbished website. Every Mac I, or my school's have bought have been refurbs. They come with the same warranty, and cost 15-20% less.
    Former Staff Member TONEAudio
    2 Ch. System
  • vmaxer
    vmaxer Posts: 5,116
    Thanks for the comments!! I'm not certain when I will get one, this gives me info on what to be looking for.
    I appreciate it a lot.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • scubalab
    scubalab Posts: 3,101
    Just getting around to chiming in here. Sounds like Scott and others have already mentioned most of what I'd recommend.
    We ended up getting our daughter a used MBP (less than a year old and with over a year of AppleCare remaining) at a price that was hard to pass up. It's WAY more machine than she needed, but it's good to know she's got room to grow with it and it will still be a great machine for years to come. I think hers is the 15" i7, touchbar, 512gb drive, 16gb RAM, dedicated graphics card. The machine was one generation older than the newest model. We purchased from a great seller who happened to also be the manager of the Geek Squad at our local Best Buy. She met with me and my daughter for nearly an hour and a half and got her all set up and gave her some great tips. For what we paid, we would have gotten less than half the machine directly through Apple. We just happened to luck out.
    I do agree that Apple refurbished is the way to go. It's a 15-20% savings off of new, and they are basically new. You just have to pay attention to what is available as their inventory always changes.
    I will also confirm that all MacBooks (including the Air and Pro) are no longer 'upgradable'. The hard drives and RAM are soldered in. So, make sure you're comfortable with what you buy.
    Lastly, although I haven't used the MacBook at all, our daughter loves it. She absolutely loves the touchbar (there are mixed reviews on it online), so it was a worthwhile bonus.
    Word of warning, this can snowball FAAAAAAAST!!! I had to step back several times and rethink some things. It's so easy to say, well, for a few bucks more we can get this hard drive, and for a few bucks more, we can get that RAM, and for a few bucks more, we can get a better video card. Those 'upgrades' can quickly add up to a substantial amount of money!
    Best of luck and stay sane in your research!
