Looking at doing a second tube amp build...
    nooshinjohn Posts: 25,922
    DSkip wrote: »
    “Those that don’t know, don’t know that they don’t know.”
    Ring a bell?
    Certainly does, and in this case it cuts both ways.... blind test between McIntosh MC601’s on B&W 802d’s at Magnolia... my amps destroyed the Mac’s by all accounts. My amps bested Bob’s 305’s at his old dealer here in Beverly Hills....
    You simply cannot claim that mine are missing something without hearing them yourself, and next time you get to L.A. you ar welcome to play with them to your hearts content. I will even send them to you to try out yourself if you pay the freight.
  • BlueFox
    BlueFox Posts: 15,251
    Never take these discussions to PM. Otherwise nobody learns anything, either about technology, or about personality.
    Your posts came across as calling my babies ugly, so to speak, and after spending so long building them, not something I care to hear. I respect what you are trying to say, and as I get closer to rolling forward, I will reach out to you. Right now they are still on the sketch pad.
    What is your opinion of high mass turntables?
  • kharp1
    kharp1 Posts: 3,453
    Its about resonant frequencies and how those frequencies get carried away from, or, transferred back in to the unit. Stone materials are notorious for being particularly bad about carrying those bad frequencies in.
    FWIW... my granite is not directly coupled to the chassis. It sits on double sided foam tape and a silicone based adhesive, so there is some isolation between it and the aluminum chassis underneath.
    F1nut Posts: 51,766
    Regardless of anything else they are beautiful amps.
