Is 'Klipsch' a dirty word on this site ?
This is an addendum to my February post, Center channel speaker connection to vintage receiver ?
    nooshinjohn Posts: 25,985
    Perhaps someone specialized in ancient languages can chime in here and help decipher your post...
    VR3 Posts: 29,536
    Vanilla didn't censor it so you must be good!
    F1nut Posts: 51,951
    Looks like you got plenty of good advice in your original thread. Not sure why you didn't simply continue posting in that one instead of starting this click bait thread.
  • boothroyd
    boothroyd Posts: 15
    Well, I bought a pair of Klipsch bookshelf speakers, RB-61 ii (discontinued) to improve my sound throughout the house. Which they do. I can hear them clearly wherever... BUT, i can't sit in front of them to listen to music. Too shrill, Too strident.
    My Polk RTi-A3's are much better for up-front listening. But sound is muffled if I'm in the kitchen, bedroom, etc... i'm a senior, hearing loss, maybe ?
    Anyway... I played these Klipsch's softly, gently for 3 weeks or so. Then played a Black Sabbath cd. Moody Blues cd. And a Telarc sampler cd.
    Powerful orchestral music, pipe organ music causes the horn tweeters to sound distorted, buzzing, crackling. Even a Bach organ recital from my TV (Pandora) 'broke up' on the tweeters.
    Did I trash these speakers, or what ?
    My equipment : HK 490i receiver. Rated @ 30 WPC (35 years old)
    Onkyo c-7030 CD player.
    Fos-power RCA cables.
    Monoprice 14 ga pure copper speaker wire (with Banana plugs)
    Samsung TV optical to 'Prozor' optical/analog converter to receiver.
    Help needed. ( F-y-B are you there)
    audioluvr Posts: 5,982
    The horns of your Klipsch speakers will penetrate through lead walls which is why they sound good other than being in front of them. Also the early HK stuff was kind of bright in my opinion which makes them sound so good with soft dome tweeters. I have friends that fabbed up a piece of foam that they stuff in the horn of their Klipsch's to tone down the highs for 2 channel listening.
  • rpf65
    rpf65 Posts: 2,127
    Nay want to try a speaker selector. In front of speakers select the Polks, out of room the Klipsh.
    Just thinking you don’t want speakers in various rooms, but there are AVR’s that will allow you play multiple sets of speakers independent or at the same time.
