Recommended cables for HT setup
Hi there,
It has been a while since I posted.
I bought some new Anthem gear for my Polk speakers and now on to the next challenge, hooking it all up.
My understanding is that for speaker wires for my center channel and my RTiA9s, I should be looking at 14 gague speaker wire. Does it matter what brand they are? Should I be looking at anything in particular ?
Basically same question for HDMI cables, power bars / surge protectors, I've seen a lot of folks recommend AudioQuest/Panamax.
And lastly, XLR connectors, worth it? if so what am I looking at when buying? Prices seem to vary for same length but not sure why..
  1. Speakers
  2. center — CSi A6
  3. fronts — 2 x RTi A9
  4. rears — 2 x RTi A3
  5. Ceiling — 2x RC 80i
  6. Subwoofer — SVS PB-3000
  • Amplifiers
  • Anthem A5
  • Anthem A2
  • Marantz AV-7704
  • DSkipDSkip Posts: 15,972
    The problem with cables in a HT rig is twofold - you have to get so damn many of them and receivers are so noisy most improvements will never fully surface.
    I’d recommend talking with Douglas Connection and getting him to build you some or doing some DIY with his Furez bulk. It’s not cheap cable but it would perform excellently in your system.
  • BlueFoxBlueFox Posts: 11,503
    I would never use any speaker cable less than 12 gauge. Even if only lamp cord.
    Bud - Silicon Valley
    Lumin X1
    Sony XA-5400ES SACD
    Pass XP-22 pre, X600.5 amps
    Magico S5 MKII Mcast Rose speakers, SPOD spikes
    Shunyata Triton v3/Typhon QR on preamp, Denali 2000 (2) on amps
  • mantismantis Posts: 15,363
    The reason most people say go with Audioquest and Panamax is that it's very good stuff. I'd say stick to that plan.
    Dan
  • VR3VR3 Posts: 23,291
    Have to throw out the supra Rondo, tin plated copper, super flexible. Sounds excellent and easy to work with. 13 awg, close to this coveted 12 awg being mentioned. 😜
    I use their wiring throughout my ht, speakers, hdmi, ethernet, power, no issues or complaints!
    - Not Tom
    Vr3Mods.com ///// Version3Audio.com
    "No, that's silly talk. Dude, you can't possibly be this audio dumb so quit the act." - Doro
  • mrlorenmrloren Posts: 2,006
    The quality of the speaker wire matters more than gauge.
    Here is what I've used in the last 5 years
    #1 Audioquest type 4
    #2 Doug's Furez https://douglasconnection.com/Raw-Speaker-Cable_c33.htm
    #3 Monoprice/Amazon Basic 12awg.
    HDMI
    I only go with Audioquest
    Interconnects (RCA)
    Audioquest
    Dougs
    SVS Soundpath
    I have no experience with XLR cables
    Family Room:
    Samsung UN75RU710DFXZA,
    Denon AVR-X4400H, Emotiva XPA3 GEN3
    Oppo BDP-93,Sony UBP-X800BM, WD Live HUB.
    Main: Polk LsiM 705
    Center: Polk LSiM 704C
    Front High/Rear High In-Ceiling Polk 80F/X RT
    Surrounds: Polk S15
    Sub: HSU VTF3-MK5
    Bed Room;
    Marantz SR5010, BDP-S270
    Main: Polk Signature S20
    Center: Polk Signature S35
    Rear: Polk R15
    Sub: HSU STF-2
    Working Warehouse;
    Sony 2100ES AVR, Sony DVP-NS3100ES for disc
    Cerwin Vega AT-12 (blasters) Advent Prodigy (listening)
    Old sony 12" Sub
    Mini tower PC with 400GB of music
  • pelhamplacepelhamplace Posts: 65
    If you were using douglasconnection what grade would be good starter cable (I.e., price per foot)?
  • F1nutF1nut Posts: 42,142
    Do you price your speakers or AVR by the pound? Of course not, so why the hell do people think it's ok to price cables, which are a critical part of any system, by the foot!?!
  • tonybtonyb Posts: 31,126
    RTIA9's- use 12 gauge from the likes of Audioquest, Douglas connections, Signal cable.
    Center you could use 14 gauge but don't go any less.
    Subwoofer ??- You could use any brand cable, but Audioquest makes decent ones too.
    Surrounds can be 14 or 16 gauge, since they are just ambient sounds.
    B&k 1430
    Tad 803 speakers
  • delkaldelkal Posts: 551
    edited July 8
    Probably because with AV its a lot of feet to those small rear surrounds..........If you buy the best cord all around you will be spending 80% of your budget for the two speakers that do the least. I would recommend going the other way and budget 80% for better cables for the mains and center. For most any cheap 12 ga wire (including lamp cord) will be OK for the rears.
    Furez 12AWG. great cable for the price
    Family Room:
    Main: Polk LsiM 705
    Surrounds: Polk S15
    Sub: HSU VTF3-MK5
    Bed Room;
    Rear: Polk R15
    Sub: HSU STF-2
    Working Warehouse;
    Old sony 12" Sub
Howdy, Stranger!
