Optical vs usb ?
erniejade
I was reading an article on usb vs optical output. Anyone ever do an actual listening comparison? While on paper i understand the theory on usb introducing noise where optical is a cleaner more isolated source, anyone actually do a listening comparison?
You know good and well you have to list a price?
I've never done a comparison. I very, very seldom use usb personally. Though my Audioquest Dragonfly was usb and I was happy with the sound. Interesting question and I look forward to hearing others experiences.Things work out best for those who make the best of the way things work out.-John Wooden -
I'm curious about this as well, recently messing with USB, though haven't actually listened closely myself.
This in reference to DAC input, yes? and from a computer?
I disabled signatures. -
From a streamer or computer to a dac. I have a aries mini coming thats going to go to a tube dac. I have been reading quite a bit on theory but, none have actually said they tried both going to the same dac.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
Wow shoot. I thought i put this in the digital section not the classified section. Sorry about that folks!Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
There's gotta be a badge for that! @Hermitism where are you?Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
I'm sure the mods will get it moved for youThings work out best for those who make the best of the way things work out.-John Wooden -
You should try stand up comedy!Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's. -
Depends on the implimentations of the USB in your piece. Some are very good, others it was more so an after thought. If your referring to the Grant tube dac, the USB isn't that great. I like digital coax myself.HT SYSTEM-
lsi 9's -
Can 1s and 0s tell the difference between copper/silver or optic transfer?
If we can....why shouldn't they?
Will those electrons or photons thumb their nose at each other's means of transfer?
Are the differences of each a matter of matter?
I pose these questions in hopes of a spirited yet civil debate.... -
On that line, i definitely heard a big difference between a pangea usb cable and the wireworld platinum 7.
I've wondered this myself. I play my digital music via USB, as my amplifier has only one USB and one optical input, and the optical is already used for the connection to my TV. Will be taking a look at this Cnet article.
Good article, I have one piece of equipment that can use AES/EBU which does me no good. I use coaxial, somewhere I read that optical can’t transfer the bandwidth/bits that coaxial can.Remember, when you're running from something, you're running to something...-me
I have a Aries mini with a TeraDak power supply that should be at my door today. Within the next few weeks, I am going to check it out myself. I picked up Stangmans's wireworld coax cable to keep it more fair since I have a wireworld Platinum Starlight 7 USB cable. Granted his is the silver but, it still should get me close enough.
