Intel CPU, Asus Motherboard & Graphic Card, Patriot RAM - $125 (LOCAL INDY)
EndersShadow
For sale is a combo of older hardware. All you need to add is a case, powersupply, and harddrive to have a fully functional computer. These parts were pulled from a fully functional computer to upgrade to new equipment. The computer was in a pet, kid and smoke free environment (my parents house) in a well ventilated case for its entire life. Mainly used as a internet/email machine. Parts never run or pushed hard.
The following parts are included:
Asus P5Q SE motherboard (w driver CD) & backplate
Intel Core2 Duo E7500 Wolfdale Dual-Core 2.93w stock Intel fan
ASUS Radeon HD 46704 gig
(2 x 2 gig) Patriot Viper PVS24G8500ELKR2
I’m not looking for trades, just cash, not looking to separate. Some flexibility on price, but as it is I’m asking ~32 bucks a part which I feel is fair. CPU heatsink was removed to take pictures, and some Artic Silver was put back on, but you will want to remount the heatsink just to be safe. I do also have a Noctua NH-U12 heatsink thats available for a slight additional cost.
LOCAL ONLY (within reason). Open to Paypal or Cash & Carry. Check if I know (and trust you
More information about each piece is below:
Intel Core 2 Duo Core2 Duo E7500
Model: BX80571E7500
CPU Socket Type: LGA 775
Core Name: Wolfdale
# of Cores: Dual-Core
Operating Frequency: 2.93 GHz
FSB: 1066 MHz
L2 Cache: 3MB
Manufacturing Tech: 45nm
64-Bit Support: Yes
Multimedia Instruction: MMX, SSE, SSE2, SSE3, SSE4, EM64T
Voltage: 0.85V – 1.3625V
Thermal Design Power: 65W
ASUS P5Q SE PLUS
CPU Type: Core 2 Quad / Core 2 Extreme / Core 2 Duo
FSB: 1333/1066 MHz
Chipset: Intel P45
South Bridge: Intel ICH10
Onboard Video: None
Number of Memory Slots: 4×240pin
Memory Standard: DDR2 1200(O.C)/1066
Maximum Memory Supported: 16GB
Channel Supported: Dual Channel
PCI Express 2.0 x16
1 x PCI Express 2.0 x16
PCI Express x1
2 x PCI Express x1
3 x PCI Slots
1 x ATA100 2 Dev. Max
6 x SATA 3Gb/s
Audio Chipset: VIA VT1708s
Audio Channels: 8 Channels
Max LAN Speed: 10/100/1000Mbps
PS/2: 2
6 x USB 2.0
1 x Optical
6 Audio Ports
Onboard USB: 3 x USB connectors support 6 additional USB ports
Form Factor: ATX
Dimensions (W x L): 12.0" x 7.8"
Power Pin: 24 Pin
Motherboard and CPU pics:
Capacity: 4GB (2 x 2GB)
Type: 240-Pin DDR2 SDRAM
Speed: DDR2 1066 (PC2 8500)
CAS Latency: 5
Timing: 5-5-5-15
Voltage: 2.1V
Dual Channel Kit
Equipped with Patriot Viper Heat Shields with integrated ACC (Aluminum Copper Composite) technology
100% Tested and Verified
RoHS Compliant
EPP Ready
Tested and compatible with Intel P35, X38, and Nvidia NF680i and NF780i boards
Recommend Use: High Performance or Gaming Memory
ASUS EAH4670/DI/512MD3
PCI Express 2.0 x16
ATI Radeon HD 4670
Core Clock: 750 MHz
Stream Processors: 320 Stream Processors
Effective Memory Clock: 1800 MHz
Memory Size: 512MB
Memory Interface: 128-Bit
Memory Type: DDR3
3D API
DirectX
DirectX 10.1
1 x HDMI
1 x D-SUB
1 x DVI
Max Resolution: 2560 x 1600
CrossFireX Support: No
Cooler With Fan
Dual-Link DVI Supported: Yes
HDCP Ready: Yes
Model: BX80571E7500
Core Name: Wolfdale
FSB: 1066 MHz
L2 Cache: 3MB
64-Bit Support: Yes
ASUS P5Q SE PLUS
FSB: 1333/1066 MHz
Chipset: Intel P45
Onboard Video: None
PCI Express 2.0 x16
PCI Express x1
2 x PCI Express x1
3 x PCI Slots
6 x SATA 3Gb/s
PS/2: 2
6 x USB 2.0
1 x Optical
6 Audio Ports
Form Factor: ATX
Power Pin: 24 Pin
CAS Latency: 5
Timing: 5-5-5-15
Voltage: 2.1V
Dual Channel Kit
RoHS Compliant
EPP Ready
PCI Express 2.0 x16
ATI Radeon HD 4670
Core Clock: 750 MHz
Memory Size: 512MB
Memory Type: DDR3
3D API
DirectX
DirectX 10.1
1 x HDMI
1 x D-SUB
1 x DVI
Cooler With Fan
HDCP Ready: Yes
Wait a minute...where is the case and if you’re not selling that, what is going in the case!?!?Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!!
We rebuilt my dads computer and reused the case, PSU and his HDDs....
"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Price drop to 100 bucks.
I might even be willing to build the computer entirely for you if you provide the case, power supply, hard drive and dvd drive...."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
I’m open to offers if anyone is on the fence. I know this stuff is older, but I’d hate to junk it."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Any interest? PM me an offer, worst I can do is say no.... but i might surprise ya...."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Any takers at 50 bucks?"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Smoking deal for anyone wanting put a rig together, for sure!
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
sold locally"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
