Are these desirable?
Living Room
Parasound HINT 6, Yamaha Aventage RX-A 1060, Oppo 103D, Cambridge Audio Azur 851N, KLH Model 5s, Polk CSi A6, Samsung 65" LED
Office
Yamaha A-S501, Auralic Aries Mini, LSiM 703s
Douglas Connection ICs and Cables
Best Answers
  • boston1450
    boston1450 Posts: 7,758
    Answer ✓
    The SDA 2b or 1c or CRS+ would be a speakers id recommend as great flexible speakers that are easy to drive with "most" receivers & amplifiers & worth the coin to upgrade.
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
    nooshinjohn Posts: 25,918
    edited March 2019 Answer ✓
    Woodland Hills, right off the 101 @Valley Circle. If you want to try SDA, I will keep a look out for a set up here. Hopefully some 1c’s will come around. I may even be able to pick them up for you and hold them until you can come up.
Answers
    F1nut Posts: 51,763
    Not really.
  • warren
    warren Posts: 756
    Google the specs and reviews.. then go buy them..
    Some final words,
    "If you keep banging your head against the wall,
    you're going to have headaches."
    Warren
  • FestYboy
    FestYboy Posts: 3,861
    But for that price I guarantee they won't sound bad! I have 2 pair myself.
  • jdjohn
    jdjohn Posts: 3,354
    How do you have 350+ posts here and not know the answer to this question? It is time you try some SDAs, if for no other reason, just to say you have owned/heard them.
  • rburgess714
    rburgess714 Posts: 618
    jdjohn wrote: »
    I know. I jumped in 2016 with the RTi series seeking advice and ended up with s60s and 703s and a bunch of other gear but yet to get some SDAs. I guess I am a new school Polk fan though I am old.
    Living Room
    Office
    It’s a bit of a haul for you, but you are welcome to come by and hear what SDA’s are all about.
  • rburgess714
    That’s a very generous offer. I may take you up on it at some point. You are in LA?
    Living Room
    Office
  • rburgess714
    Sending you a PM
    Living Room
    Office
    There is a set of 2b’s for sale in Placentia for 250. Those would be a great way to go.
  • codycatalist
    codycatalist Posts: 2,662
    Worth every penny.
  • boston1450
    as usual. Vanilla has screwed up another thread. The Accepted Answer thing is just stupid. It moves post around in a thread
    Randy-Maine
    by David WMG
    xschop Posts: 5,164
    edited March 2019
    Can't comment earlier?
    Vanilla should seriously consider a new flavor.
