Centre speaker help
jd79
jd79 Posts: 1
hi all, I'm running a pair of Tsx550t and an old Yamaha centre speaker and want to upgrade. Just wondering if I should stick to the tax series or could I go for the csi a6 or ...?? any thoughts would be appreciated, cheers.
  • Geoff4rfc
    Geoff4rfc Posts: 2,970
    jd79 wrote: »
    It's usually best to stay timbre matched within a series...…...but right now I'm running an LSiM center with RTiA speakers and everyone is playing together just fine.
  • mrloren
    mrloren Posts: 2,474
    I run a CSi-A6 with Signatures plays fine. I am also using a modern AVR with Audyssey calibration which EQ it in well.
  • Pinktulip7
    Pinktulip7 Posts: 249
    I just upgrade from Csi A6 to LsiM 706c,huge upgrade, noticeable difference in Sound quality!!Timbre match is not necessary...
    TV :>Panasonic TC-P55VT50
    RECEIVER :> HARMAN KARDON AVR 7300
    FRONT :> L & R :> POLK RTI A9 500 W
    AMP :1> PARASOUND HALO A21 250 W
    AMP :2> EMOTIVA UPA-1 200 W
    CENTER :> POLK LSiM 706c 250 W
    SURROUND SIDE :> POLK RTi A3 150 W
    SURROUND REAR :>POLK FXI A6 150 W
    DVD PLAYER(HD) :>TOSHIBA HD X-A2
    DVD PLAYER(BLU-RAY) :>Panasonic DMP-UB900
    POWER CONDITIONER :> PANAMAX M5400-EX
    SUBWOOFER :A> SVS SB16-Ultra 1500 W Front
    SUBWOOFER :B> SVS SB16-Ultra 1500 W Rear
  • rooftop59
    rooftop59 Posts: 8,120
    I am a little surprised to see that folks are happily mixing the LSiM and RTiA series, but I am not surprised to see the rest of Polk mix and match, like the RTiA and signature. I am even using a Polk center with non Polk speakers, and it doesn’t bother me at all. I would say get the CSiA for sure, much better center.
    Game Room 5.1.4:
    Bedroom 2.1
  • Geoff4rfc
    rooftop59 wrote: »
    Be surprised not my off balanced polkness, but embrace the madness that is aloof and be glad for the happiness!!! :smiley:
  • afterburnt
    afterburnt Posts: 7,892
    I had a CSiA6 with various main speakers none of them in that series and I thought it sounded great for movies. In my limited personal experience, I don't think that timber matching is that important for movies. And believe me, I am quite limited. Multi-channel music may be a different story but I am not so much into fiction.
  • honestaquarian
    honestaquarian Posts: 3,259
    The Polks all have the same basic sonic signature, so mixing and matching between series usually isn’t a problem. I have a pair of SDA SRS 3.1TL’s with a CS1000p Center. A pair of Monitor 5jr’s for surround duty and an RT-35i for back surround. I’m also using a pair of mini monitors for height duty. All from different series and generations, but working towards the same seemless surround sound goal (especially when the THX processing is engaged)
  • Derm
    Derm Posts: 95
    A little late to this discussion but I will add another plug for the CsiA6 for centre use.
    I am using mine now with a pair of Lsim707's as front mains & 703's for front presence and the A6 is doing just fine.
    I do want to eventually get the LsiM706c when I can get my hands on one but I am in no rush due to the performance of the A6 so far.
    Speakers
    Front - LsiM707, Front presence - LsiM703, Future ATMOS - VS 700LS
    Center - LsiM706c, Rear surrounds - 80 F/X LS, VS 900LS. Sub - (pair) Klipsch R-12SW
    AVR - Yamaha RX-A3010
    AMP - NAD C275BEE
    Main HT - LG 4K 75”, Sony UBXP800M2
    Bedroom HT - LG 55" 4K, Philips BDP7501 4K UHD player , Yamaha SRT-1500 sound projector, Spare room HT LG 50” plasma, Yamaha BD-671
    Office - Pioneer X-CM56, Bose iPod dock
    In Storage - 4 - RTiA9, RtiA3, CSiA6, FXiA4, Blackstone TL1
    The only source of knowledge is experience. Albert Einstein
  • Geoff4rfc
    edited March 2019
    Derm wrote: »
    I am using mine now with a pair of Lsim707's as front mains & 703's for front presence .
    Wow, if you've got A9's and 707's up front together, that's got to sound pretty bad A$$!!!
    That's what I see in your signature anyway, has it changed??
  • Derm
    Derm Posts: 95
    edited March 2019
    I don’t have the A9’s hooked up at the moment. Just the 707’s, 703’s and A6 plus the 2 subs. No rear channels either.
    I have everything in a temporary location to the side of a sitting room. The basement is unfinished in my new home so once done I plan to get more amp’s to power them up and use the 707’s and the NAD for a 2 channel.
    Those 703’s sitting on the A9’s will get dedicated stands once in a permanent location.
    Speakers
    AMP - NAD C275BEE
  • Geoff4rfc
    Derm wrote: »
    Have you ever employed the "wide" channel? I have used two different bookshelves but when I went with a tower, my world changed.
    On set up, I had the mains toed in and the wides pointing straight...….what an incredible sound.
    Anxious to see your arrangement once it's completed.
