what he said... (in three parts) Part 3
ALL212
Where subjectivity actually works
During the driver evaluation process, any sort of subjectivity is a bad idea. But on the other hand, subjectivity during the system evaluation process is going to be required. At some point, a designer has to decide on tradeoffs. That could mean deciding what types of distortion are more annoying to the designer personally. For example, what sounds worse: a broad, large increase in even order harmonic distortion in the lower midrange and bass or sharper but narrow band odd order harmonic distortion in the upper treble? Sound familiar? It's the old metal vs paper cone debate and it comes down to personal preference. The choice is a subjective one. Some prefer metal cones while many others prefer paper or poly. That's OK. Measurements can tell the truth about a driver but remember that they can't tell you what you like.
When a proponent of subjectivity repeats what I just mentioned above, I'm not going to dispute it. Many things in the end come down to personal preference. A system design decision can be subjective, but testing and evaluating drivers individually must remain objective.
Detail is a crappy word
This is a word that is used by people who don't know how to properly describe a speaker's performance. It is merely a vague indicator that something sounds pleasing, and it means different things to many different people. It could mean more distortion or it could mean less. Detail is an audiophile "power word" that means nothing but sounds good rolling off the tongue. It sure sounds better than just mumbling "I like it" every time a speaker impresses.
I might advise substituting two different words that work a little better: clean and smooth. Clean can mean low non-linear distortion. It would mean a lack of harmonic frequencies that are different from the fundamental frequency reproduced. Clean can mean hearing only what's in the original music and nothing more. Smooth can mean low linear distortion. Of course this could mean a smooth frequency response, but it also means low energy storage which is directly related. Rise and decay time are all related to frequency response smoothness.
The crappy words and phrases list
Aside from the word detail, there are a lot of other audiophile wannabe "power words" and phrases. All are vague, non-descript and useless. Some phrases are deceiving, such as soundstage width, depth, or height. What people are really hearing is a system's power response and it's interaction with the room. Open up a Stereophile and read a page to obtain a plethora useless audiophile terms. Some of the offending single-words might be transparency, image, bite, snap, grain or resolution (in reference to anything analog) and so on.
Multi-word phrases are even worse. Veils have been lifted gets a special achievement award for overused bad cliche. It doesn't end with phrases like pace, rhythm and timing and black spaces between the notes. Any description of music played during evaluation or any description of cables or interconnects used during evaluation also fall under this category. I won't go on for fear that I might cause nausea. Just be aware that there's a lot of it out there. Some of it is obvious and some is not.
Common system comparison errors
•Non-linear confused with linear distortion
For those who are not familiar with the terms, non-linear distortion is any type that adds additional frequencies to the original fundamental frequency. Linear distortion is anything related to deviation from flat frequency response. Harmonic distortion by it's nature can make a speaker seem to have a bright tonality. It might measure flat, but upper harmonics not in the original recording can change perception of the tonality. It takes a deep familiarity with a reference recording and a keen ear to be able to tell the difference between linear and non-linear distortion.
•Woofer issues confused with tweeter performance
Related to the above, a poor choice of a crossover point on a woofer (too high) can often lead a person to believe there is a distortion or level problem with a tweeter. A woofer could be generating harmonics well into the range that the tweeter is covering. When a listener declares that they don't like a tweeter they heard in a system, 90% of the time it's the woofer and the design that's actually the problem.
•Low end distortion is not good bass
Smallish woofers often trick people into thinking bass performance is good. There's a mindset that more is better, but when listening to tiny woofers trying to reproduce the bottom three octaves, you're not hearing "more" bass, you're hearing "different" bass. Bass distortion causes audible harmonics above the fundamental. On a small scale, this sounds like a warm tonality. On a large scale it can't be any better described than aural mud. Be careful before declaring a woofer as having good bass. If a person is unfamiliar with what good bass is, they could just be hearing muddy distortion.
•Dull or veiled vs vibrant or exciting
When comparing the sound of two systems side by side, the first impression is often that the more distorted speaker seems more detailed, and the more accurate one seems dull or veiled. A speaker could often be described as vibrant or exciting by ears that are unfamiliar with clean sound. Even when set to the same level, the more distorted speaker will seem louder, and louder immediately seems better. Eventually, the distortion that causes "vibrant and exciting" will turn to listening fatigue, but it happens slowly. It's usually too slow to make quick A-B comparisons useful. If you really want to compare speakers with your ears, you had better live with them for a good long time. Otherwise, take some measurements to get the truth right away.
The fact that listening fatigue takes a long time to set in does not bode well for making comparisons on a showroom floor, or at a DIY event for that matter. The favorite of a DIY event is most likely not the best performing speaker. On the showroom floor, it's a well known fact that some speakers are intentionally inaccurate to help them stand out. The unknowing consumer then takes home a poor performing speaker only to realize days or weeks later that this speaker doesn't sound as good as they thought. The DIY'er building a project they heard at an event is often disappointed with the result after living with it a while.
Page done by John "Zaph" Krutke © 2006
Also visit -Zaph|Audio-
Aaron
Enabler Extraordinaire
Whatever your into I guess, but reading these articles makes me objectively want to find a new hobby.
I like to say that reading about hifi is like reading about... umm... reproduction.
I mean -- you can read about it; but empiricism is so much more enjoyable.
Tomato
Tomatoe
"Audiophiles are the male equivalent of cat ladies." - Audiokarma Member -
LOL. Many ‘audiophile’ descriptive phrases make no sense.
Three 20 amp circuits. -
So in my journey for better sound I found it odd that two 8" woofers could sound deeper, faster (punchier) and more accurate than a 12" woofer. Then I realized it was all about how accurately the amp controlled the movement of the cone. The larger cone required more work, due to it's greater mass, to move in, out then stop on a dime to produce certain dynamic bass reproductions. Other things would play a part in this action such as rigidity of the cone itself and the ability of the surround medium to not interfere in the cones travel from point "A" to "B".
One big reason I chose Polk Audio SDA's (back in the 80's) is the design of the drivers seemed to address all of these issues. Also the PR is, in my opinion, FAR superior to other designs of the era. I'm sure there are better speakers out there that have also addressed these limitations. Infinity's polymer cone woofers are another great example. They are light and rigid but use a foam surround which increase resistance as excursion increases, not to mention break down over time. Klipsch resolved this with their KG4's using two 8" polymer woofers with butyl rubber surrounds.
No offense to those here that have moved on to "non-Polk" speakers.
"Fast bass" is a phase that I could never understand.
The speed of sound being frequency independent and all...
I caught a strong, heavy bass and et it. Edible bass....
How does the author feel about toe-tapping and goosebumps?Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
96 have read post 1, 23 read post 2 and 131 read post 3.
Attention span?
These weren't posted to do statics but I found that interesting.
Aaron
Enabler Extraordinaire -
I b'lieve I read all three.
I am funny that way.
Other ways, too.
