REL Acoustics Carbon Fibre Limited
tratliff
tratliff Posts: 1,810
Anyone have experience with the REL Carbon Fibre Limited subs?
I have avoided subs the last few years but I am starting to wonder if my so called full-range speakers (Legacy Focus S/E) would benefit from providing help in the lowest region.
From my research I understand high-level input would be best for better system integration. This sub has them and from what I have read could be the best use of high-level integration in the industry. I would need two since I am running mono block amplifiers and a pair would also provide better system cohesion.
The cross-over would likely be set to its lowest setting to not overlap the mains but only fill in where they drop off.
I have watched many uTube videos and read many white papers that support both ‘do it’ and ‘dont’. Our lovely internet will tell you whatever you want to hear (pun intended).
From you polkies that have been down this path please provide some experiences you’ve had along with pros and cons either way.
As always thanks for input.
  • rpf65
    rpf65 Posts: 2,127
    Can’t speak about that specific sub, but I think that every speaker can benefit from external subs. Reason being is that you position your speaker for the best overall presentation in your room. That positioning may not be the best position for bass. I’m sure there are exceptions.
    Your particular speakers are one of the few out there that are capable of producing the low freqs, that wouldn’t need a sub, if positioning for optimum bass response, by some coincidence is also the best position for overall presentation. Best way to find out is room sweeps, from 20-80 Hz. Providing one has the gear and wants to invest the time, that will answer your question.
    As far as Rel products, in a strictly 2-channel application I personally can’t think of a better choice. Some will disagree, and agurably JBL, Funk, Seaton, and a few others may be preferred. I’ll not argue with them, they all sound slightly different so once again the best for one may not be the best for others.
    I do think if you get an external sub, you’ll want to reconsider that lowest setting idea. I would think somewhere in the 40-60 Hz range is where you’ll find issues, weather using your ear or room sweeps.
  • tratliff
    edited March 2019
    rpf65 thanks for the feedback. I will play with the crossover setting and look into doing some sweeps.
    I should be able to get one on loan to help with my decision. Just wish I could get two.
    Post edited by tratliff on
  • Joey_V
    Joey_V Posts: 8,603
    The S5 with the Gibraltar woofer I believe?
    I looked at getting a couple just recently. Deal killer for me was lack of paramterics.
    I have not heard it personally.
    My friend has dual Gibraltar G1 however so I’m sure they sound similar
    nooshinjohn Posts: 25,995
    I run a single S5 with my SDA-SRS 1.2TL's and had no troubles with pulling signal from both of my monoblocks, so you can start with just one. It integrates so well with my SDA's that I don't even know it's there, but I can feel the reinforcement of the bottom end. It really tightened things up without drawing attention to itself and instead placed more focus on the music. They are a great sub as the regular S5 SHO, so I can only imagine the Carbon will be that much better.
  • tratliff
    Joey_V wrote: »
    @Joey_V How was the system with dual Gibraltar’s? Would be nice but I can’t stretch my budget that far.
  • tratliff
    @nooshinjohn Tell me more about your integration with the monoblocks. How did you connect the S5 to them? Red to left positive, yellow to right positive and where did you connect the black lead? Seems straight forward to me but REL advised me against it.
  • tratliff
    I have the single S5 in the system now. Your description is exactly what I have found.
    The ground lead is jumpered to the grounds of both amps. Not the optimal solution, but my amps support that. You need to check with your amplifier maker and see what they say.
  • tratliff
    Thanks for the info. I’ll give them a call tomorrow to see what they say. But I do think I have made up my mind to get two. So it really should not matter.
    I would try with one first. Two would be harder to tune I would think. The last thing you would want is to actually have them start to dominate.
  • Joey_V
    Joey_V Posts: 8,603
    Duals give better balance.
  • tratliff
    edited March 2019
    So, I placed the order for a pair of the Carbon Fibre Limited.
    I’m still testing with the single S5 and really liking the authority this adds to the system.
    Will be interesting to have 2 knowing how one performs and also what the limited, with the upgraded driver, will provide.
    Should be 1-2 weeks before I have them. I’ll post some pictures and listening thoughts after I give them a good run.
    Thanks for the thoughts and ideas!
    If you need a new home for the stock S5, I may be interested....
  • tratliff
    Sorry John. It’s a loaner from the dealer. It’s going back when I pick up the pair.
