Welborne Labs 9vdc external supply for Squeezebox Duet
ALL212
$65 shipped.
Welborne Labs 9vdc external supply for Squeezebox Duet. As an addition it'll come with a slightly larger connector - still 9v out but Welborne shipped the wrong wire on the first go around. So you get the correct connector for a Duet and a bigger one for anything else you have that needs 9V.
This isn't just isolated to the Squeezebox. Any device desiring clean 9V could use this. You might have to find the right connection to the device.
Aaron
Enabler Extraordinaire
PM'd
great deal, man. Makes a very discernible SQ difference!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Rats...this might have worked with my Matrix XSPDIF-2 :^ /2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
