NAD C 658 or Cambridge Azur 851N Streamer
gudnoyezgudnoyez Posts: 6,725
https://nadelectronics.com/product/c-658-bluos-streaming-dac/
This Streamer Dac looks like it could give the Cambridge 851N a run for its money both are priced the same, and feature wise it looks like this NAD might be a good choice. I'm in no super rush but plan on one of the 2 sometime soon.
I'm not sure if NAD will be at Apoxona but if need be I might find a NAD dealer in Chicago or drive up to Madison to check one of these out. I probably dont need to use all the features the NAD offers. Has anyone had the opportunity to check the C658 out? I was thinking about the Cambridge unit until I seen the reviews on the NAD.
  • tonybtonyb Posts: 30,863
    wow, that puppy is loaded with all sorts of goodies.
    HT SYSTEM-2 channel
    Dynaudio Audience 72
    Cary xciter dac
    Cullen modded Sonos
    Joule la-100 pre
    B&k Ref 4420 amp
    Analysis plus crystal oval ic's
    B&k 1430
    Tad 803 speakers
  • tophatjohnnytophatjohnny Posts: 2,164
    Little brighter than the 851N. Nice piece Steve. They both are.
  • displaynamedisplayname Posts: 170
    At first glace they seem pretty comparable, but I think it will all come down to what you're looking for. The 815 seems more like a streamer that could function as a preamp, and has a very serviceable DAC for those that want it.
    The NAD seems like a preamp, that is focused on streaming and being a real one box solution. It seems built to be that one box solution for the growing market of powered speakers in my mind. Plus adding a phono preamp while eliminating a digital out points more towards a true one box push. MQA was a smart marketing addition, and so was using the BluOS. But no DSD, and no digital output will probably be a deal breaker for some.
    Both have a few advantages and trade offs, so I think it's a good option if it checks the right boxes for you.
    Analog: MoFi MasterTracker > MoFi UltraDeck > Sutherland 20/20
    Digital: Sony CDP-CE375 / Streaming > Cambridge CXN v2
    MastersounD Dueventi > JBL Studio 580 or Arcam rHead > Hifiman HE4XX
    Discogs
  • gudnoyezgudnoyez Posts: 6,725
    edited March 11
    Failed to see that it plays only converted DSD files, good catch.That wouldn't be a deal breaker for me as my Oppo 105D is fine with DSD files plus SACD playback, plus my Marantz plays SACDs. I have no intrest in downloading DSD files to stream, but I can see where it would be a deal breaker for some. Decisions, Decisions. It's down to one these 2 or maybe a Blusound vault.
    Ahh.. Just get all 3 !!😂😂😂
    The Nad is billed as a Dac first, so not having the digital output makes sense. Though to me, anything that streams one might want the option of adding different dacs to the mix.
    HT SYSTEM-2 channel
    Cary xciter dac
    Cullen modded Sonos
    Joule la-100 pre
    B&k Ref 4420 amp
    B&k 1430
    Tad 803 speakers
    tonyb wrote: »
    I think that would be the deal breaker for me. I don't currently use an external dac, but I've heard what one can do so I don't like the idea of limiting that option.
    Discogs
  • erniejadeerniejade Posts: 4,718
    No wifi on it for the streaming side. Holm Audio by me is a NAD dealer. If I have a shot this weekend, I was going to stop by there anyway. I will check and see if they have one in stock.
    Lumin D1,Wireworld Silver Eclipse, KEF LS50 Wireless, Velodyne SPL1200, Technics 1200, Denon DL160, Jolida D9,
    USB helper: w4s Recovery
    Living Room Teac AI-3000,T+A PA 1530R, LSI25, SDA 3.1TL, Aries Mini, Grant Fidelity Tube Dac 11
    Have but haven't used in a while: LH Labs VI Dac, Cayin SCD50T
    It has wifi Brian, it's in the specs.
    HT SYSTEM-2 channel
    Cary xciter dac
    Cullen modded Sonos
    Joule la-100 pre
    B&k Ref 4420 amp
    B&k 1430
    Tad 803 speakers
    You sure Tony? I only saw Bluetooth quality Bluetooth aptX HD wireless built-in.
    On some other brands, some headphones and cars, when I see them describe like, Bluetooth "wireless" is not wifi wireless like hit your router. Unless there was another spot or I am reading it wrong.
    Network connectivity
    Gigabit Ethernet RJ45
    WiFi 5 (802.11 b/g/n)
    HT SYSTEM-2 channel
    Cary xciter dac
    Cullen modded Sonos
    Joule la-100 pre
    B&k Ref 4420 amp
    B&k 1430
    Tad 803 speakers
    Thanks Tony. I completely missed that one. I will see if I can go to Holm and check it out possibly put it against the Node.
  • DSkipDSkip Posts: 15,550
    It has no digital out.
    My suspicion on sound would be a darker background and better details with the Cambridge. I imagine the NAD will have a muddiness to the imaging that the Cambridge won't have. I'd honestly expect it to compete more with the CXN soundwise, but I could be wrong.
    I actually prefer the 851N as a streamer/DAC over the AURALiC Altair I had. The Altair is a bit dry in presentation and the 851N is more musical. The thing holding the 851N back is no USB out and no DSD. The former is an issue for my systems as I use external DAC's almost exclusively, but the latter isn't an issue whatsoever.
    audiothesis.com/
    Speakers: Harbeth: 30.2, SHL5+; Usher: Be-10, T-515; Rosso Fiorentino: Elba, Pienza, Certaldo, Fiesole, Volterra; Polk: T50, Signature S15, RTA 15tl, RTi12; Sonner Audio Allegro Unum, Legato Unum, Legato Semis, Legato Duo; Emerald Physics CS-2.8; Klipsch KLF-20
    Preamps: Shuguang S200MK, Dayens Ampino, Parasound P5
    Amps: Shuguang S845MK, Dayens Ampino Monoblocks, Parasound A23
    Integrateds: Triode Corporation TRV-88SER, MastersounD: BoX, Dueventi, Compact 845, Evolution 845; North Star Design Blue Diamond
    Sources: AURALiC Aries, Denon HEOS Link, North Star Design: Magnifico, Supremo, Incanto, Intenso, Venti
    Cabling: Wireworld
    TV: Sony XBR-75X940C
    Well NAD, Cambridge, and Blusound all have rooms at Axopona, so I will be on a mission. Bran if you check it out impressions please, I'm just glad I can check them all out in April at the show.
  • ClipdatClipdat Posts: 6,216
    gudnoyez wrote: »
    Cambridge told me that they will be demoing their new Alva turntable at Axpona. Hopefully they'll have some of their streaming gear going as well though.
    • "Electronic music is human sound adapting to indulge technology, and for some, it feels like the signature sound of energy. New and abstract sounds over hypnotic rhythms can conjure vast soundscapes for escape, pleasure, and transcendence."
    edited March 12
    Or put em all to rest and get yourself a Cambridge Audi Edge NQ 💡I'm sure looking at doing it but I'm slow to change and my 851N is a nice piece.
    Post edited by tophatjohnny on
    erniejade wrote: »
    WOW, to say he didn't like it much is being polite.
    HT SYSTEM-2 channel
    Cary xciter dac
    Cullen modded Sonos
    Joule la-100 pre
    B&k Ref 4420 amp
    B&k 1430
    Tad 803 speakers
    Not sure where the Audi part slipped in there ?? Maybe I was typing Azur but don't even know if the Edge NQ is part of that line or not. I'm just knowing the Edge is an intriguing piece and it has me thinking hard.
  • audioluvraudioluvr Posts: 1,031
    Well if you're steering towards the 851N I may be selling mine.
    Kidding. I love this thing. Imaging is crazy good! It's a keeper for me.
    Home System:
    SDA 1C's - Full mod with the help by Dave...
    800 Va Dreadnought- Speaker Interconnect
    WireWorld Mini-Eclipse 7 speaker cables
    Cambridge Audio Azur 851N - DAC/Streamer
    B&K Reference 50 Pre/Pro
    B&K M200 Sonata Monoblocks
    BLE-Design 16mm Power Cables
    Denon DVD 2900
    Sangean HD FM Tuner
    Barn system:
    SDA SRS 2.3's Full mod done by myself
    Carver C-1 pre
    Carver M1.5t
    BluDenso - Bluetooth receiver/DAC
    edited March 12
    O or put em all to rest and get yourself a Cambridge Audi Edge NQ 💡I'm sure looking at doing it but I'm slow to change and my 851N is a nice piece.
    Just checked this one out drool! :o $4000 is a bit over my budget, I would get %6 off purchasing from World Wide Stereo using the discount from some employee purchase sight through work. It will still be over my budget with the 6% off. I'm looking forward to checking it out.
    https://www.worldwidestereo.com/products/cambridge-audio-edge-nq-preamplifier-with-network-player-c10973
    She's a beauty.
    A bit over my budget too, but it's going to happen when I get a few other things out of the way. 😃
Howdy, Stranger!
