Herbies Fat Dots
Soft Fat Dots (Large) - 6 total never used - very clean - first owner. Very compliant material, space age material, doesn't break down.
Herbie's Soft Fat Dots provide plenty of compliance for micro-vibration control. Material doesn't mar or "ooze," doesn't dull higher frequencies or mess up the bass like Sorbothane and other soft, compliant materials. Softer than dBNeutralizer Fat Dots, Soft Fat Dots add more compliance when needed for small weight load, extra vibration control, or uneven surfaces. Soft Fat Dots are fast and highly responsive to microdynamic nuance, sonically neutral, very musical.
Large: for severe vibration conditions involving speakers weighing up to about 30 pounds. Recommended in place of factory feet for use with turntables, CD players, preamps, and other components where a low profile is desired. Dimensions: 1-5/16" (33.3mm) diameter by 1/4" (6.4mm) thick.
Asking $55 shipped worldwide
For Sale 2019:
Tortuga Audio LDR passive preamp
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center
