Candy store for OPPO owners?
http://www.oppomod.com/
Has anybody tried their wares?
HT:Polk LSiM 706 LSiM 705's VR3 LSiM 703's LSiM 702's| Marantz AV7704 | Sunfire TGA-7401 | Oppo UDP 203 | Sony PS4 Pro| Directv Genie HD DVR | Samsung 75" Q8 QLED | SVS PB13 Ultra | MIT EXP 2's (Fronts & Center)
ManCave: Parasound Halo A21 | Parsound Halo A52+ | Marantz AV7002 AV PrePro | Usher Dancer Mini-x DMD's | Usher BE-616 Center | SVS Ultra Surrounds | SVS SB4000 Sub | SVS SB2000 Sub | Oppo UDP 203 | MIT Shotgun S3's | PSAudio Stellar GCD | Music Hall MMF 5.3se TT w/ Soundsmith Carmen | Mytek Brooklyn DAC+ | Lumin U1 Mini | HP Elite Slice PC | ROON'd for life | Samsung 50" SUHD TV | Sony PS4
Office |Cocktail Audio X14 | KEF LS50 | Peactree Nova 125SE |
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 | Bluesound Node |Polk SDA SRS 2.3 |
  • GlennDogGlennDog Posts: 2,032
    Following
    Nut'n better than plug 'n play mods . . .
    Power Rogue M180 monos & Adcom GFA 5802
    PS Audio PerfectWave Power Plant 10
    Rears Salk SuperCharged Surrounds
    Source PSA PWT into NSD Supremo
    Pre/Pro Integra DHC 40.1
    LCD Samsung LN46B750
    Mains Salk HT2-TL
    Center Salk HT2C
    Pre Cary SLP-05
    Wires WW & MIT
  • mantismantis Posts: 15,404
    Thanks Mikey now I have something else to obsess over.... B)
    Dan
  • pitdogg2pitdogg2 Posts: 14,303
    Dang that looks like good stuff.
  • Mike ReeterMike Reeter Posts: 3,504
    Good stuff, I like the I2s Upgrade Card option, as I have a PS Audio DAC. This would allow a successful transfer of SACD from my 203 to the DAC, similar to the PS Audio Combo.
    SDA SRS 2.3TL's/SDA SRS 3.1TL's/SDA CRS+4.1TL's and some other stuff
  • Mikey081057Mikey081057 Posts: 6,586
    edited March 9
    I saw that too and then said my god you can do $2K in upgrades to your 203..
    The I2S is very intriguing...as are the linear power options. I ordered the I2S and a PSAudio Stellar GCD.
    B)
    Agreed, there is a "get around" solution now to pass the SACD content from the 203 to the PSA DAC, the Upgrades offered here look to be a much "easier" path for the Tech Challenged, such as myself ;)
  • decaldecal Posts: 3,170
    If you've ever wondered how tubes would sound in your system, send your oppo to Modwright for their "Truth" tube modification.
    http://www.modwright.com/#
  • DSkipDSkip Posts: 16,112
    B)
    You would want to make sure it is the same protocol. Like XLR there are different configurations for i2s
    edited March 9
    Yes there is no standard
    I contacted the dude and he configures it specifically for the PS Audio I2S
  • JayCeeJayCee Posts: 564
    edited March 9
    DSkip wrote: »
    B)
    From the oppomod site:
    "many manufacturers are following the PS Audio standard. This specification uses the HDMI terminal physically (not the HDMI transmission standard). Currently PS Audio, Holo Audio and Javs DACs are confirmed for compatibility."
    Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio BHK Signature & 250, Perfectwave DirectStream Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: Core Power Technologies EQUI=CORE 1800 Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends FLAC Streamer: Roon ROCK on wifi'd NUC⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
  • DarqueKnightDarqueKnight Posts: 6,569
    I have ordered a LPM SE for my UDP-205.
    "So hot it burns Mice!"~DK
    "Polk SDA-SRSs are hopelessly out of date both sonically and technologically... I see no value whatsoever in older SDA speakers."~Audio Asylum Member
    "Knowledge, without understanding, is a path to failure."~DK
    "Those who irrationally rail against something or someone that is no threat to them, actually desire (or desire to be like) the thing or person they are railing against."~DK
    Looking forward to your results Raife.
    My results were outstanding, in both picture quality improvements and sound quality improvements. I'll let the new power supply run in for a couple of weeks before I post my full review.
    Installation was easy.
    My immediate results were:
    1. Brighter, clearer, more detailed picture, with better color rendition.
    2. Sound was apparently much louder, due to the significantly lowered noise floor. I actually had to turn the volume of my home theater pre-pro down 4 dB.
    3. More tactile sensation.
    4. Sound stage size didn't change, but image weight increased significantly.
    5. I notice more small details, both with video and audio.
    Figure 1. Oppomod Linear Power Module Special Edition for Oppo UDP-205.
    Figure 2. Oppomod LPM SE installed.
    Figure 3. Stock Oppo switch mode power supply on left, Oppomod LPM SE on right.
    Figure 4. Still images photographed from OLED TV screen. Picture with stock power
    supply on left, picture with Oppomod power supply on right. Images are from the beginning of "Alien Covenant" at time 00:01:17.
  • codycatalistcodycatalist Posts: 2,527
    Wow that picture difference is astounding.
    Wow that is remarkable.
    Maybe I shoulda named the thread Crack for Oppp owners.
  • honestaquarianhonestaquarian Posts: 2,497
    The pic on the right looks more real. The one on the left looks nice, but it looks more like a stylized picture and not real.
    Living room Home theater: Upgrade Company modified Onkyo PR-SC5509,Sunfire Cinema grand Signature 5 channel amp(1st gen),Carver TFM-45,Carver M-400a,Panasonic TC-P50ST60 50" Plasma(last gen before Plasma production stopped)Pioneer Elite DVL-91,Meridian 519 Dolby AC-3 RF Demodulator,Oppo Digital UDP-205,TiVo Bolt VOX,Nakamich BX-300,Technics SL-1200MKII,Shure V15 Type VxMR cartridge,Polk SDA-SRS 3.1 TL(with RD-0198 tweeters, upgraded with Larry's rings, black hole5,an Avel-Lindberg 1000VA isolation transformer, VR3 customer crossovers and internal wiring),Polk CS-1000P(with SL-6506 tweeter),Polk Monitor 5jr(with RD-0194 tweeters),Polk RT-35i (1),Polk Mini Monitors,Polk PSW150(4)Monster Power HTPS 7000 MKII Signature series,Monster Power AVS 2000 Signature Series,Various MIT,Monster,Upgrade Company and Belden interconnect,power,HDMI,Coax and Toslink Digital and speaker cables.
    Bedroom 2 channel system:Integra DTM 40.4,Nakamichi BX-100,TiVo mini,Musical Fidelity X-LPS,X-PSU,Carver TFM-25,Sony KV-34XBR970(last of the widescreen tube sets before production stopped)Technics SL-1200MKII,Shure V15 Type V MR cartridge,Polk RT-55(with SL-6506 tweeters),Polk PSW-200 in plexiglass(2),Sony Playstation 3 slim.Monster Power HTPS-7000,Monster AVS-2000, PowerVarious Kimber,Audioquest and MIT interconnects and speaker cables.
    Makes me really wonder how much more the SE version brings to the table since the standard made a big difference.
    edited March 30
    This is the SE version. See the captions for figures 1 - 3.
    The scene was filmed in a white room with blueish lighting from a large, expansive picture window. For those unfamiliar with "Alien Covenant", the movie begins with a closeup of the android David's eye as he is sitting in a chair looking at the picture window and describing what he sees.
    The noise content caused an overemphasis of blue, as well as a loss of fine detail and brightness. A significant reduction in noise brought the picture into better color balance.
    The captures below are from the same scene (captures taken from the Internet).
    I'm virtually sold on the LPM. Look'n forward to your final analysis . . .
    Mains Salk HT2-TL
    Center Salk HT2C
    Pre Cary SLP-05
    Wires WW & MIT
    Yeah
    What he👆🏽said!
    I'm sorry Raife I missed that. I seen wire color and it matched the website pictures for the non SE version
    My apologies :)
    Maybe I shoulda named the thread Crack for Oppo owners.
    That would be close to the mark.
    I'm trying to resist replacing the power supplies in the UDP-203s in my home office and master bedroom...because it would be way overkill. I find myself craving the same increased depth, detail, and color "pop" that I see on the home theater TV.
    Maybe we can do a group buy.... I have 2 x 203's
    Stupendous!
    I'm down ...
    Mains Salk HT2-TL
    Center Salk HT2C
    Pre Cary SLP-05
    Wires WW & MIT
  • BlueFoxBlueFox Posts: 12,028
    Are these mods simply plug and play swapable parts?
    Bud - Silicon Valley
    Lumin X1
    Sony XA-5400ES SACD
    Pass XP-22 pre, X600.5 amps
    Magico S5 MKII Mcast Rose speakers, SPOD spikes
    Shunyata Triton v3/Typhon QR on preamp, Denali 2000 (2) on amps
    Some of them like the one @DarqueKnight did are. Some of them require soldering skills. Tap the link in the OP’s first posting to see.
    @DarqueKnight Just curious to see if you have further review of the mod you did of your 205?
    Nothing further since I posted this:
    https://forum.polkaudio.com/discussion/comment/2505063
  • displaynamedisplayname Posts: 403
    I had not seen this thread until today, but I have to say that photograph of the still of the eye is insane. I'm not of a videophile at all, but seeing it like that really tells the story of what a power supply can do. I wish more things in audio could be shown with that type of immediate and obvious comparison via the internet.
    Analog: MoFi MasterTracker > MoFi UltraDeck > Sutherland 20/20
    Digital: Sony CDP-CE375 / Streaming > Cambridge CXN v2
    MastersounD Dueventi > JBL Studio 580 or Arcam rHead > Hifiman HE4XX
    Discogs
Howdy, Stranger!
