Album art....I know, it's like doing taxes
steveinaz
Those of us with ripped CD libraries that didn't have the intellect to figure out how to make our ripping software also download album art, UNITE.
I've re-visited this topic many times in my OCD ridden brain because it bugs me that I have no art for my library. Finally I found something that is minimally painful to use. It's been mentioned before, but last night I decided to check it out.
It's called "Album Art Downloader" it's FREE, and it works really well. I loaded a bunch of 320 mp3 rips I had on my laptop for copying to my cars usb stick, that were down-conversions from my flac library. You simply run the program, pull your library into it's window, and it will initially scan everything to see if you already have art for any of your music. Then you simply check the checkbox next to the album that you need art for, and hit search. A number of album pics will come up in all different resolutions, pick the one you want--then tell AA where you want the file copied. Move on to the next album.
Works fast once you get into a rhythm with it, and I'm gonna go home tonight and start populating my flac library FINALLY. Thankfully I only have about 400 ripped CD's, so I'll let you know how fast the process goes.
If this issue has been a thorn in your side, download AAD and give it a shot. It's a very simple program, and I'm a simple person---so I like it. No options to setup, about a 30 second learning curve. It just works.
https://sourceforge.net/projects/album-art/
Post edited by steveinaz on
I'm fairly obsessive about album cover art too. Even though JRiver does a good job of finding cover art especially on relatively popular or recent albums, I almost always go to Google Images and see what's the best cover art file there. Amazon used to be a great resource, but they stripped almost all of their customer upload cover art out for some dumb reason.
It takes a long while to do things the way I have done, and the tool above looks like it would help speed things up.
I even go to the extent with classical albums from large boxed sets that are impossible to find the original covers for of scanning or photographing the CD cover and editing into a usable jpg. -
When it populates the screen with album art thumbnails, it tells you the dimensional size, kb's, etc. Holding your mouse pointer over an image will enlarge it.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Thanks for the link.
mp3tag also helps to find the album arts. -
Thanks I have been doing a lot of ripping lately on DB Poweramp and I have some titles that did not get tagged I will download it and try it out.Home Theater
I did 34 albums last night in about 45 minutes.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
I use PerfectTunes. It does album Art, ID Tags, Duplicates and has AccurateRip.Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. SnubWay, Main Stream
I use foobar2000 for ripping/tagging, but Album Art downloader is far easier/faster for cover art.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Done! 406 CD's done in about 5 hours.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
It only took me like 10 years....LOLSource: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
