jriver app for Fire tablet???
PSOVLSK
PSOVLSK Posts: 5,396
edited February 2019 in Going Digital
Is the jriver app not available for a Fire tablet?
Tried to download, but got a message that my device is incompatible with the app.
Obviously seems as though I'm out of luck, but I thought it was weird to not be able to get the app.
  • PSOVLSK
    Thanks Ryan.
    Not a big deal since I have the app on my phone and on an iPad, but would have been nice for how I was wanting to use it.
  • Thorton
    Thorton Posts: 1,324
    “Google” adding Google Play on a kindle fire. You can side-load Google Play then download apps from the play store. I’m running Roon on a Fire 8 and it works fine.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • PSOVLSK
    And this is why I went ahead and asked what I thought was a dumb question. Seems as though someone always has a solution around this place.
    Playing jriver through my Fire as I type this:)
    Thanks!
  • stretchl
    stretchl Posts: 1,334
    @PSOVLSK How do u like jriver? I’ve been using a squeezebox touch but now that I have an oppo bdp105 hardwired to my network I’m looking for a better option. Thanks.
    - Isaac Asimov
    Hi-Fi
    Cabling by Groneberg
    Visuals
  • PSOVLSK
    I like it, but I've never used anything else so I don't really have a point of reference. I'm pretty much a novice at this digital music thing, but I still found it fairly easy to set up and use.
    I pretty much just choose an album or song I want to listen to and that's it. In other words, I haven't really spent any time making playlists, etc. I've made some very simple playlists (ie: Van Halen) and it will automatically play all of my Van Halen albums.
    It doesn't (or I haven't figured out how to) allow random play of an artist or genre using jremote unless you make the aforementioned playlist. This can be done on the computer though.
    I think the sound quality is great, but again I have no point of reference other than Amazon Music so...
    Maybe others will chime in with more info for you.
  • stretchl
    Thanks.
    - Isaac Asimov
    Hi-Fi
    Visuals
