Odyssey Audio Stratos Extreme Dual Mono Power amp
ALL212
For Sale: The Odyssey Audio Stratos Solid State Power Amp. Purchased by me less than 5 years ago and checked over by Klaus since then. Warranty will be transferable. This has been my primary power for the last three years or so.
This is the Dual Mono Extreme amp. It has two power supplies and two boards, one for each channel. It carries the full compliment of 16 caps, 8 to a side. It's also a beast @ over 70 lbs. Massive heatsinks on both sides. This is NOT what Klaus would consider a Kismet version. But this is the version just prior to the Kismet.
Selling due to a recent acquisition that nullifies my need for this.
Specs Kinda here: http://www.odysseyaudio.com/products-stratos-stereo.html
Klaus no longer sells (but he does support) the dual mono amps.
Here's the monoblocks: http://www.odysseyaudio.com/products-stratos-mono.html
Polky Price is $1600 shipped/insured, you pay fee's if applicable. I do accept and prefer paypal friends/family. I just shipped a similar one so my cost is about $100 to ship and insure.
I'll also include two heavy 14g power cords.
Aaron
Enabler Extraordinaire
Pre Weekend Bumpy. $1500 with above terms.
If you can pick it up or need it delivered within 100 miles of Rockford, IL make it $1400.
Aaron
Enabler Extraordinaire -
BIG Bump...
$1000 - you pay shipping. Depending on where you are that could come to about $100.
The rest of the Odyssey gear has gone and I really don't need this one here anymore.
EDIT - the Kismet gear remains!!!! Only the past system is about gone. Tempest is gone and the Candela is just waiting payment.Post edited by ALL212 onAaron
Very nice price, not sure you could do better for the same money- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Dayng!
Hey Aaron, what are the general specs on this, since it's dual mono? Couldn't quite figure that out from the product pages.I disabled signatures. -
If you just pick on a mono stratos you'll be right there. Notes in italics
◾1 x 180 Watts RMS @ 8 Ohms (each) - per channel
◾2 Ohm load stable
◾Class A/AB
◾1 - 600,000 Hz frequency range
◾120,000µF memory (each)
◾120 amps current delivery
◾<0.04% THD (not audible)
◾>800 continuous damping factor
◾Input impedance 22K ohms
◾DC offset <1 mV
◾RCA & XLR (bridged) inputs - not true XLR
◾400 VA Plitron transformer (each) Has one for each board
◾Sanken Epitaxial Planar Transistors 2SA1216 & 2SC2922
◾Anti vibration dual thickness PCB - These are the top end Black boards
◾Power consumption when idle ±30Watts - double that
◾4 internal fuses 250V/6.3A, 5x20mm, fast blow
◾Additional electrical protection fuse
◾>56 lbs weight / 25.4 kg closer to 75 lbs
◾Dimensions: 19 width x 18 deep x 7 height (in) /
48.3 width x 45.7 deep x 17.8 height (cm)
Aaron
Having met Klaus, seen his shop and heard his creations, I can attest that his stuff is first rate. I’d never previously heard of anyone doing a 20 year warranty. He also loves doing upgrades, so this dual monk could open up a wide road toward your audio future.“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Cabling by Groneberg
Visuals
http://Vimeo.com/channels/stretchphoto -
...this dual monk could open up a wide road toward your audio future.I disabled signatures.
Smartbuttt…
You can always take a chants with Klaus and Odyssey Audio. It's really not even a chants you're taking.
I always wanted to be a Gregorian Monk. But I never got the chants.
Had enough?!!!
MSG chant forget it either"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
As long as I have a chants to change this...
Correction:
7 caps per side - 14 total.Aaron
That's a shame... I was a buyer at 8 per side- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Well...if you count the bypass caps there are really 20, 10 per side.
so...when can I expect payment?Aaron
I only pay in avocado's at the moment, our currencies do not align- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
maybe...
at an average cost (non-organic and organic) of about $1.40 each...
Can you provide 800 avocados in good saleable condition? Should come to about 300 lbs. you pay shipping.Aaron
Hmm, I will check with my suppliers along the southern border... First, if you could remit $500 as a good faith deposit to the royal crown of avocadoism, and in return, once we have clearance for said product, I will pay this fee back along with interest in addition to the purchase price.
Also, do not worry about shipping, I have comrades in your area who will pick up and arrange shipment.
Please, feel peace in our transaction as I am royal blood.
Best regards
Haba jaba avocado prince- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Hang on...contacting the Nigerian prince finance officer for funding...Aaron
Mr. Prince said he won't do it for less than $50,000. Something to do with small change, prison and transfer rates.
2nd Price drop - $900 for the weekend.Aaron
Thats a whole lot of amps....assuming this would benefit from a dedicated circuit...or two!!
PM coming.
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
PM checked, everything appeared ok.
You two have any questions?
Cool - I’m always open to questions, didn’t want anyone to think a stone was left unturned!
What does he have? Or is it classified!!!Aaron
That's cool, being stoned and all, I understand.
There is the possibility that this may replace the Butler I picked up from Tony. Just getting to that time to experiment a bit. There's also the possibility that the Joule may, MAY, go on the market. I'm probably going to pick up a PSA BHK pre and check it out. I'm kind of liking the idea of a complete PSA system. -
I would be SERIOUSLY interested in your comparison of the odyssey w the butler. Please share when you get aaron’s amp and congratulations on a great buy!
Ps - @kharp1 which JOule do u have? I’m on mobile and can’t see sigs.“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Visuals
Also interested in a comparison between the Butler and Odessey. Tony spoke highly of how the Butler and Joule matched up. I have had the Butler high on my amp list since picking up the Joule from him.
