Can I put SDA SRS 2 on a 13' wall?
I have chance of getting a pair of SDA SRS 2. I have room that is 20' X 13' with 10' ceilings. Can only put speakers on the 13' wall. Is it worth getting them or is 13' wall to small?
Best Answers
    Tony M Posts: 11,728
    edited February 2019 Answer ✓
    I'd say they would be fine. How far would you be sitting from them?
    I heard a set of them in a 12X12 bedroom and they sounded fantastic! B)
    Answer ✓
    I have not purchased them yet and want to make sure the room is big enough. They would NOT be 6' apart, only 4ish.
    Your room is the right size for them. ;)
Answers
  • I would be sitting about 8' from them.
    Yea, you'll be VERY HAPPY!
    I was sitting in my own set-up on a 9' triangle point. 9' center to center on the speakers and me being 9' to each center of the speakers too. Magic happens! B)
    I think my speakers are 8" off the wall. I'll go check in a couple of minutes though to be sure. Spike the speakers also. ;)
  • Spike them? It's on a laminet floor. There is no carpet
  • Also, your speakers are nice and far apart. Mine will only be close to 4' apart. You say that will still be okay
  • FestYboy
    FestYboy Posts: 3,861
    Ideally they should be as closyt to 6' apart as you can get (inside to Inside measurement). Most of us have them between 5" and 6" off the wall depending on room response. You can spike any speaker on any floor type...
  • I have not purchased them yet and want to make sure the room is big enough. They would NOT be 6' apart, only 4ish.
  • FestYboy
    I still would get them, the dimensional imaging will suffer a little, but the end result will be far better than a standard pair of speakers in the same area.
    You should've stated in your earlier posts they would only be 4'ish apart.
    Anyway, mine are 6" off the wall.
    I love their sound being in the sweet spot or walking around doing other things or even being outside the building. They are FULL RANGE and powerful or delicate. Depending on the model, they might need a powerful amp to play loudly for an extended period.
    Now... what other speakers have you had experience with?
  • Sorry about not saying they would be 4 feet apart. I just figured since the room was 13' that I would probably want to keep the suggested 3' or so from outside walls. That would result in about four feet from each other. That's what I was worried about.
  • As far as other speakers, I have had some Polk Monitor 7, 10s and SDA 2b's. Also had a pair of Marantz HD 770's and JBL L100T.
  • Thank you guys for your help.
    You've got some great history of nice speakers there. ;)B)
    Spread the speakers more if get them. like I said, the SRS2's I heard in a bedroom were 16" from each sidewall and I still heard an impressive soundstage.
    Let us know if you get them, OK?
  • I certainly will. There is also some SDA 1C's floating around but I was thinking the SRS 2 would probably be better?
  • One other thing. Do you think my Parasound 2125v.2 will have enough power for them?
    I haven't owned any Parasound amps yet(YET.LOL) but I've heard they're very powerful capable amps. All of them in their own wattage ranges. Yours seems to be powerful enough but maybe a Parasound SRS owner will chime in and tell you real world experiences.
    I have a 4 ohm set of SRS2's. There are 8 ohm versions too. I hope the set you're looking at is an 8 ohm version but don't pass up a set if the price is right or they're gifted to you like my first set was.
    SRS2's...BASS you can feel. B):D
    Your amps specs...;
    https://www.audiolab.com/parasound-2125-v-2-two-channel-power-amplifier/
  • Great. Thanks. I am looking forward to getting them!!
  • FestYboy
    The 1Cs would be a good option if you desire to upgrade the IC system. That is if the 1Cs are pin-blade.
    NICE! B)
    Pick one of your favorite songs to christen them with after you set them up in your own home. ;) I'll bet you'll smile a BIG smile!
    I have my SDAs only about 2 feet or so from the side walls and about 5 1/2 feet between. I have some pretty good dimensional imaging, granted I wish my room was a couple feet deep so I could get more bass out of it.
    Get the SDAs
    ick them up but man it was worth it. Original owner who bought the in 87-88. Immaculate condition. Even had the interconnect, manuals and copy of the receipt from 88. Take a look.
  • Those look great! Late model SRS2s are very nice.
    Those are nicer and better than the 2 pr. I've owned. ;) Nice acquisition!
    I think yours are 8 ohm too.
  • Thanjs. They are in great shape. The guy I got them from had a beautiful house and everything in it was in prestine condition including the speakers. I could tell he really didn't want to get rid of them but his wifey didn't mind.
    F1nut Posts: 52,005
    Proton gear and SDA's were good matches back in '88.
  • He actually mentioned the Proton stuff but not in a complimentary way?
    audioluvr Posts: 5,987
    Crap! He paid $1,999 for those new? They still look new! Nice score!
    They weren't 2K new for MSRP were they?
    I've been undervaluing mine then!
