what would you use?
wangotango68
wangotango68 Posts: 1,056
edited February 28 in Clubhouse Archives
what would be a good woofer,tweeter combe for these speakers? the artical does not say what brand is used.the driver are 8inch and i assume the tweets are 1inch dome
scott:cool:
Post edited by RyanC_Masimo on
  • mantis
    mantis Posts: 17,056
    edited April 2002
    you got em, I can't figur out what they are.....
    Dan
  • wangotango68
    edited April 2002
    they are called the opel here is a linkopel
    scott:cool:
  • nascarmann
    nascarmann Posts: 1,464
    edited April 2002
    MW8002 driver and SL6501 tweeter? That is what's in the RT7's.
    Oh, the bottle has been to me, my closes friend, my worse enemy!
  • RuSsMaN
    RuSsMaN Posts: 17,987
    edited April 2002
    They scream Vifa/Scanspeak to me. Depends on what you want to spend, really. Although, looking at the woofer, there's a chance that could be an Audax design....(esp if it is stressed as a budget design)
    You got any more info?, esp with a 8inch, 2-way design, I would think the network is bought assembled, thats a not-so-easy design to pull off, and have sound right....
    Cheers,
    Russ
  • hoosier21
    hoosier21 Posts: 4,408
    edited April 2002
    Scott
    www.audioc.com has a speaker called the Opel, they use to have speaker "kits" for the DIYers. I would call them and see if it is still offered. Guessing at drivers and crossovers it risky to say the least, the best drivers and a mismatched crossover will be an expensive waste of money.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • hoosier21
    edited April 2002
    Now that I checked the link, it looks like www.subwoofers.com is where you buy the Audio Concepts speakers as kits, It is 369.00 for the kit, why not just buy it? Remember KISS (Keep it simple stupid)
    Russ
  • wangotango68
    edited April 2002
    the driver i found out are the (vifa m21wo-39 for the woofer)
    and the (vifa d27tg-05 tweeter)
    scott:cool:
  • wangotango68
    edited April 2002
    after 3 hours of work today my cabnits look like these i would have snaped a picture but the wife has the digital camera this
    weekend in chicago. hell no russ im not buying the kit that takes all the fun out of it. thus pick shows the cabnit glued together
    we added screws in addtion to glue but no biscute joints.hell this speaker is built like a brick **** house very heavy.
    scott
