: NICE Parasound Halo 2.1 integrated COMPLETE
Unfortunately I am selling my Parasound Halo integrated amp. I am the original owner and it was purchased from an authorized dealer. This one is black ,works perfectly and looks great and is complete with double box ,manuals, power cord and remote . The taxman calls and something has to give. If you are looking at this you know what it is. There are many positive pro reviews in this in fact I remember thinking that I do not recall seeing so many reviews on an time in a long time. Needless to say power a plenty. Five analog inputs, 2 sub outs that can be controlled, nice phono and headphone stages The details are below. Having had many integrated amps I would describe the sound as very neutral. and musical with some meat on the bones. Looks great and works as it should asking just $1495!!!!
Preamp and DAC Features
Latest generation ESS Sabre32 Reference DAC (ES9018K2M)
Asynchronous USB 2.0 supports PCM up to 384kHz/32-bit
USB input decodes Native DSD64, DSD128, DSD256 and DoP DSD
Windows USB drivers for ASIO & WASAPI - Download here
Mac OS does not require any drivers
Coax and optical accept PCM up to 192kHz/24-bit
Analog bass management with high & low pass crossovers
Home theater bypass input for surround sound integration
Front panel subwoofer level control
Dedicated high current headphone amplifier (TI TPA6120)
Phono for MM & MC with 100 Ω or 47k Ω load
Front panel Aux input with automatic +12 dB gain stage
5 pairs RCA line level Analog inputs
1 pair XLR balanced Analog input
Balanced XLR and RCA left and right preamp outputs
1 balanced XLR and 2 RCA subwoofer outputs
Bass & treble controls with relay bypass from remote or front panel
Rear panel IR input and IR loop output jacks
12 Volt input and output to triggers
Back-lit remote control with discrete buttons
0.5w standby power consumption meets Energy Star & EU specs
Power Amp Features
160 Watts x 2 @ 8 Ohms (RMS, both channels driven)
240 Watts x 2 @ 4 Ohms (RMS, both channels driven)
Power amp circuit topology designed by legendary John Curl
Direct amplifier input to bypass preamp section
High bias class A/AB operation
Oversized shielded toroid power transformer
Dual-mono power supply and power amplifier
40,000uF power supply filter capacitance
Matched JFET input stages and MOSFET driver stages
12 high voltage/high current bipolar output transistors
Heavy-duty 24k gold-plated 5-way speaker binding posts
Over temp and short circuit relay protection
  • schwarcw
    schwarcw Posts: 7,360
    Very nice!
    Carl
  • BC6
    BC6 Posts: 109
    Arg! I’m kicking myself. This is a great price and a great amp. I just paid $1650 for mine two weeks ago.
    2 Channel: Atohm GT-1 speakers, Atoll IN400 integrated amp, PS Audio DirectStream DAC, PS Audio NuWave Phono Converter, Pro-Ject Debut Carbon Esprit SB with Ortofon Bronze cartridge, SotM sMS-200 ultra streamer, SotM sPS-500 power supply, and homemade infinite baffle subwoofer with two Fi Audio IB318 drivers.
    HT: All Polk: SDA 2.3tl fronts, CSiA6 center, 500-LS ceiling, RT/FX, RTi8, Monitor 4 rears, plus Yamaha CX-a5100 AV Preamplifier/Processor, Yamaha MX-a5000 11.1 channel amplifier, and Sony XBR55-AE1 OLED TV.
  • geppy1
    geppy1 Posts: 3,076
  • CottageChz
    And here I thought I was checking this forum enough! Missed it! Sorry you had to let yours go but at least it sold fast.
