And, in other "I'll sure be glad when this 'tube amp' fad passes" news...
mhardy6647
Parts Express tries, yet again, to capture some of that market.
https://www.parts-express.com/dayton-audio-hta20bt-hybrid-stereo-tube-amplifier-with-bluetooth-42-usb-aux-inputs-headpho--300-3840
Let's see:
gratuitous use of tubes? check. (two small-signal triodes, no really gratuitous power output tubes, thankfully)
hybrid? check.
goofy 'tube cages'? check.
'transformer bump' that may or may not enclose a transformer? check.
Bluetooth? check.
Let's see:
hybrid? check.
Bluetooth? check.
Ok, Jerry, we're ready to sell these in Brooklyn!
Meh.... no DAC or phono stage.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Actually, to this thing's credit, it has two inputs and a line-level subwoofer output.
EDIT: oh, and a headphone jack, albeit on the back panel.
nooshinjohn wrote: »Meh.... no DAC or phono stage.
For a hunnert and twenty four Samoleums?! Whaddya expect?!?
Actually... you know, if it had a capable DAC, I just might... ummm...
no.
NO!
I actually kinda dig the tube "cages".
Guess I need to go stand in the corner for a while and think about what I have said. -
Small signal tubes don't need cages. They were Born Free...
OK, apparently this thing uses "6F1" tubes.
I am pretty much striking out on info on the (Chinese, presumably) 6F1 tube type.
I am guessing it's a pentode(?!?)
Anyone know anything about the "6F1"?
Just curious
@mhardy6647 go for it!
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
This guy looks to be similar. 6F1 based.
https://hifi-exquis.com/hybride-amplifier/68-xiangsheng-h-03a-hybrid-6f1-tube-amplifier.htmlBasement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Beauty shot:
What’s up with the blue led glow around the tube?! Do people actually like that?
Just for grins I'd like to hear one of those things on my khorns as they've got enough power for a decent evaluation. I'm not quite curious enough to justify buying one though.
Apparently...
OK, it's green not blue -- but it's just as hideous.
motorstereo wrote: »Just for grins I'd like to hear one of those things on my khorns as they've got enough power for a decent evaluation. I'm not quite curious enough to justify buying one though.
I suspect that the K-horns would quickly reveal the amp's shortcomings.
That Chinese 6F1 isn't the same tube as the western 6F1. The Chinese one is, I'm guessin', a pentode something like the one used in those thirty-one dolla preamps that some folks have gone nutso over. -
Ah gotcha! Weird that they give it the same designation.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
BTW, vacuum tubes are s'posed to glow like this.
DSC_9988 by Mark Hardy, on Flickr
photo taken by my son:
https://doctorhardy.wordpress.com/
http://icouldbeahero.blogspot.com/
unless their filaments are thoriated tungsten, in which case, they're more like this.
source: http://vinylsavor.blogspot.com/2014/04/tube-of-month-801a.html
Yea the real Burning Electrons color...
Not THAT fake hippy glowing schtuff....
I.... A .... mean nothing against hippies...man -
Found this. http://tdsl.duncanamps.com/tubesearch2.php?TSD=6f1&btnSubmit=Query
Hey I have decent tubes in my Thirty-one dolla preamp!
"Audiophiles are the male equivalent of cat ladies." - Audiokarma Member -
codycatalist wrote: »Found this. http://tdsl.duncanamps.com/tubesearch2.php?TSD=6f1&btnSubmit=Query
Again -- the TDSL link is for a "western" 6F1, not the miniature tube found in the titular amplifier
The Chinese 6F1 is, to quote Churchill, a mystery wrapped in an enigma.
As long as you don't have 60 dolla tubes in a 30 dolla preamp, it's OK
I'm ok with this blue, though!
mhardy6647 wrote: »BTW, vacuum tubes are s'posed to glow like this.
Found a cross reference guide that proclaims the Chinese 6F1 is equivalent to the E80CF! Never heard of that one either!
mhardy6647 wrote: »codycatalist wrote: »Found this. http://tdsl.duncanamps.com/tubesearch2.php?TSD=6f1&btnSubmit=Query
Some people charge $60 for the tubes I have in it currently (Western Electric 403B) but I only paid $7.99 plus shipping. Glad I pass the Doc Hardy test of frugality.
Also my apologies on the wild goose chase of a link, when I found that info posted someone referred to it as the Chinese Valves.Just a dude doing dude-ly things
