Got 1Hz? i, Robot does
PolkThug
PolkThug Posts: 7,532
edited December 2004 in Music & Movies
Suspicions confirmed.
Post edited by PolkThug on
  • RuSsMaN
    RuSsMaN Posts: 17,985
    Mmmkay.
    What amp do you have (or source for that matter), that can reproduce it?
    Cheers,
    Russ
  • PolkThug
    My test equipment only goes down to 10Hz, so thats all I can confirm on my system.
    Edit: My source is a Denon2200, and I have twin SVS PB10's.
    Test equipment is Behringer ECM8000, Behringer802, TrueRTA L4 and a laptop.
    I did not create the above graph, it is from Home Theater Forum.
  • Dr. Spec
    Dr. Spec Posts: 3,780
    That waterfall is simply a digital stream from the LFE channel. MingL probably created it with freeware.
    There are a few subs capable of playing down into the 10-15 Hz region, but this list is very short.
    The majority of that passage is centered at 25 Hz (the pink blobs), with plenty of still strong (but lower amplitude) stuff at 18-22 Hz. A tough test for any sub, no doubt.
    Sounds like you are digging your new-found deep extension capabilities, polkthug. Hearing things you never knew existed, eh?
    SVS
  • PolkThug
    Yeah, its been fun to go back through my movies and enjoy the "subtle" differences. :)
  • hamzahsh
    hamzahsh Posts: 439
    Doc, can you list some of the 10-15hz capable subs? Just curious to know!
    Panasonic TH-50PX80U Plasma HDTV
    Polk Audio RT800i (fronts)
    Polk Audio CS400i (center)
    Polk Audio F/X1000 (side surrounds)
    Polk Audio RTi6 (back surrrounds)
    Velodyne CHT-15 (subwoofer)
    Yamaha RX-V1400 (Pre/Pro)
    NAD C272 (2-ch Amp)
    Adcom GFA-7605 (5-ch Amp)
    Toshiba SD-3109 (DVD/CD player)
    Malata DVP-580 (Multi-region DVD player)
  • Dr. Spec
    Velo DD-18, Velo 1812, SVS 16-46 PCi, PC+, Sound Physics Servo-Drive. Any properly designed Infinite Baffle. Any properly designed vented DIY sono-sub with an EBS alignment. I'm sure there are others - this is just off the top of my head.
    SVS
  • wallstreet
    wallstreet Posts: 1,405
    BTW, that's a kick **** sequence. Had some folks over for Christmas and happened to have the DVD from Ballbuster. So I flipped over to this sequence. A great workout for the HT system. All those poor souls watching the demo still listen to tv with the tv speakers.
